    Hello
    My build has been going slower than i thought and to build my current round rail design and upgrade will take a lifetime so i have Emailed Fred at BST Automation. I thought it would be easiest if I got everything at once to make the freight cost better. but i'm not really sure if i have got everything correct on my parts e.g the correct voltage for the motors and drivers. i haven't asked him for power supplies because i Forgot.
    Would you say its better to do it this way or buy the parts as and when. It would make my simple brain think the build was a better price to fool me and make the nearly truths more believable to my wife.
    Here it is my great pleasure to quota the price for you,for
    Hiwin 20 mm Rails & Blocks
    2pcs hgr20 - 1200mm Rails
    2pcs hgr20 – 1000 mm Rails
    2pcs hgr20 – 300mm Rails
    12pcs HGH20CA Carriage
    1set RM1605-L1000mm ball screw with ballnut
    In standard end machined and 1000mm is the overall length.
    1set BK12/BF12 End support
    1pcs 1605 ballnut bracket
    4pcs 8x10 Flexible coupling
    X1 Water Cooling Spindle Kit 2.2KW CNC Milling Spindle Motor + 2.2KW VFD + 80mm clamp + water pump / water pipe for CNC Router
    X4 Nema23 3A 425oz-in Motors
    X4 Motor Controllers
    Best price is USD1300.00,included the freight by Fedex.
    Some details,
    1)The Linear rail and carraige are in original HIWIN brand.
    2)We will machining the ball screw end in standard,and 1000mm will be the overall length,included the machined part.
    3)The BK12/BF12 we quota to you are in cheaper type with Deep groove ball bearing,if you prefer higher accuracy and the BK12 in Angular contact bearing,we can offer to you,and the cost will increase USD18.00.
    4)Not fully understand what's your meanning of "X3 1605 Couplers",maybe you mean need some extra coupling?and I quota to you for 4pcs 8x10mm coupling to you,8mm are for the stepper motor shaft,and 10mm are the machined ball screw end.
    5)The NEMA23 motor we quota to you are in 8mm shaft diameter,3A and 425oz-in.
    Delivery can be arranged in 5-7 working days.
    Anything can do for you,please contact,thanks.
    Thanks for your reply.
    The motor driver is DM542 model,
    For 2.2kw spindle motor,will send 4pcs bearing version to you.and the main spec. is,
    1) Dimension: 80*240 mm
    2) Power: 2.2KW
    3) Voltage: 220V
    4) Frequency: 400 Hz
    5) Speed: 0-24000 R/min
    6) Water Cooled
    7) ER20 collets chuck
    8) Runout off: less than 0.02mm
    Best wishes
    Fred
    I would be very grateful if you could look to see if i'm on the right road, Last time I went ahead with the sbr20 without asking ans regretted it. the machine isnt really designed for any particular use and so an all rounder is hoped for and hopefully make a little back in time on small jobs
    Rob
  1. FOR SALE: SBR 20 supported round rails and bearing blocks
    By JoeHarris in forum Items For Sale
    Last Post: 09-02-2015, 02:06 PM
  2. WANTED: 2 x 20mm Fully Supported Round Rail
    By longy in forum Items Wanted
    Last Post: 30-03-2014, 09:21 PM
  3. round, supported or profiled rail?
    By mocha in forum Rails, Guideways & Bearings
    Last Post: 26-07-2012, 03:44 PM
  4. WANTED: 2 x 20/16mm supported round rail
    By D-man in forum Items Wanted
    Last Post: 30-10-2011, 11:08 PM
  5. Profile v Supported Round Rail
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 15-09-2011, 09:29 PM
