  1. #31
    Hi Clive,
    The smoke came from the component in small red circle. Before smoke - it got very bright...
    It was only 12V power wires connected to the BOB from 12V supply.
Name:	2016-10-04 14.10.17 (Medium).png
  2. #32
    Finally received new HDBB2. Connected and all looks good - I can drive all axis finally :) Only one issue - don't know why, UC300, when connected to external power source of 5V (jumper settings correct) my pc does not see the board connected... Once I disconnect external power source, reposition jumper to use 5V from USB - PC can see the board and all works just fine ? Any ideas why is that and is it ok to use it without external power source ?
    Also, I'm bit confused how to drive relays from two different sources. I want to use outputs from HDBB2 and UC300 to activate relays. Here is a diagram how I connected it at the moment:
Name:	How to wire relay array.jpg
    But, the relays is not working that way... (I can activate them via Arduino with that wiring though). I could use this type of connected (external power supply connected to power relay coil, but from where I shall take 5v to activate relay ?)
Name:	How to wire relay array 2.jpg
    Could anyone help / guide me how I shall wire the relay board ?
    Thanx :)
  1. 2.2KW water cooled spindle and Altivar 12 2.2kW 230V 1ph to 3ph
    By gabi68 in forum Generic Chinese Spindles
    Last Post: 14-10-2015, 07:37 PM
  2. Altivar inverter - setting maximum speed
    By JohnHaine in forum Motor Drivers & Controllers
    Last Post: 06-01-2015, 09:12 PM
  3. PSU wiring help needed
    Last Post: 25-06-2014, 11:46 AM
  4. Driver wiring advice needed...
    By Wal in forum General Electronics
    Last Post: 09-06-2014, 06:11 PM
  5. Newbie Initial Wiring/Setup
    By Rikk in forum Motor Drivers & Controllers
    Last Post: 28-06-2011, 10:19 AM
