  1. #31
    Without re-reading the entire thread, NPN means it's switches the signal wire to ground.
    So connect the sensor +VE to 24V, then the Gnd/0V to both the 24V supply GND/0V, and the BOB GND/0V (best to join both power supply GNDs at a common point).
    Then connect the sensor signal wire to the Gnd/0V/- side of the opto input, and 5V to the 5V/+ side of the opto input.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #32
    For all practical purposes the proximity switch behaves like a Normally Open mechanical switch.
    Most people are overthinking the problem.
    If your BoB input when unconnected is shows a light on the Mach3 diagnostics screen when it is configured, then the BoB has internal resistors to float the input 'High'. Putting a switch, relay or Normally open proximity switch (like wot you got!) between Ground and the BoB pin will push the input to Ground (Low) when operated and trigger the selected function.
    The Black wire in the untriggered state has a high impedance and so it is possible to parallel them up to put all home switches to one input. I would use a routing diode on each output. If you are unsure I will breadboard a test and video it.
    The Black wire will sink 300mA to ground. Any more than that, the switching transistor in the output stage of the device will make smoke signals that it has failed, and may even give you an audible indication (BANG!).
  1. Proximity limit switch problems
    By davrich in forum General Electronics
    Last Post: 12-03-2018, 01:58 PM
  2. Wiring 3 wire proximity switches in series
    By mikem in forum General Electronics
    Last Post: 02-05-2016, 09:33 AM
  3. 3 wire proximity switch help
    Last Post: 06-10-2015, 03:24 AM
  4. Proximity switch NPN or PNP
    By Matt81 in forum General Electronics
    Last Post: 19-04-2014, 11:38 AM
  5. Proximity Wiring Problem
    By Bruce in forum General Electronics
    Last Post: 13-01-2014, 07:21 PM
