Thread: 3 ball screws ~ 1000mm long
Looking for 3 ballscrews with nuts ~1000mm long,
Max dia 16mm, ideally 14mm. Round nuts preferable, dont have much room for the nuts
03-02-2017 #2
Hi johnsattuk,
Please feel free to check out our wide range of ballscrews on our shop, I've attached the link below.
http://www.worldofcnc.com/collections/ballscrews
Feel free to give us a call anytime to discuss any queries,
Regards,
Chephren Marchant
07932560707
19-02-2017 #3
Good day
14 mm is not a dimension widely manufactured. Typically it is 16 or 12mm.
What is axial force? 12x5 can go up to 1800N, however with 1000 mm length bulking is already an issue (not a case if you are using only "pull" force). What is the max. rpm (feed rate).
For diameters up to 20mm, ball nut load capability is typically much bigger than capability of the bearings.
Ball screw Unit price Ball screw nut Unit price
SCR1204*1000mm $7.95 SFU1204 $7.95
SCR1210*1000mm $10.59 SFS1210 $17.65
SCR1604*1000mm $8.83 SFU1604 $8.83
SCR1605*1000mm $7.95 SFU1605 $7.06
SCR1610*1000mm $7.95 SFU1610 $7.95
SCR2004*1000mm $10.59 SFU2004 $10.59
SCR2005*1000mm $9.71 SFU2005 $8.30
SCR2010*1000mm $11.48 SFU2010 $11.48
Prices from one of the china supplier.
DHL = ca 200$, delivered within one week.
End shaft machining 30 $
custom...
regards
martinLast edited by fifa; 19-02-2017 at 08:52 PM.
21-02-2017 #4
i'm going to have 2 1605 ballscrews available soon. I think they are 1200mm long with round ballnuts. they will need proper end machining as sit only has rudimentary machining on them at the moment, but I will let them go quite cheaply. let me know and I can post pics etc
21-02-2017 #5
Thanks for the offers, should have mentioned that I got the screws from Germany a couple of months ago.
21-02-2017 #6
no problems will just put them up for sale instead. glad you got some
Fitting ball screws to Chester 16V
By Tom_Nelson in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 19-02-2017, 07:31 PM -
have you put ball screws on an X2plus?
By bmbaz in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-05-2014, 06:56 PM -
buying ball screws
By bmbaz in forum Marketplace DiscussionReplies: 2Last Post: 10-05-2014, 03:57 PM -
RFQ: 7mm Ball on 4mm bar 15mm long (as 1 part) x 50
By Fletchirwin in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-01-2014, 10:00 PM -
Best way to machine ball screws?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 34Last Post: 17-06-2012, 05:10 PM
