Page 3 of 3 FirstFirst 123
  1. #21
    After following this thread for a while and being completely baffled by the circle/hexagon thing, I then had a look at Neale`s fusion drawing, and decided to try cutting a few of these dovetails out. Although I have fusion 360, I still find it easier to work in solidworks so, I downloaded Neale`s fusion 3D drawing and exported it as a iges file. Then in solidworks I opened it up, seperated a single tile from the three, and saved it. After opening it back up as a single file I then shrunk it down to a maximum outer diameter of 48mm, (the width of the piece of scrap chopping board I had lying around was 50mm) and saved it as a dxf. I am now about to go out to the mill and try cutting a few out
    If this works, I will take a couple of pics to let you see the results. Just to add, I cannot take any credit at all as I am using both Neale`s drawings, and Peters original input for this experiment. So, big thanks to you both as I think it is a very nice looking and unusual joint !
  2. #22
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    It will be great to see an academic exercise turn into reality! Out of curiosity, what CAM package will you use to go from dxf to gcode?
  3. #23
    I`ll be using cambam, just going to try it right now, back in 10 mins
  4. #24
    Well that was quick & painless, seems to have worked a treat
    Thanks to Neale & Peter.
  5. #25
    Excellent. Good to see that it all works. I think that the corner radius was a good plan as it makes the design accessible to those with routers but not laser/plasma/water jet cutters (which probably means most of us) but thanks to Peter for the initial idea and doing the bulk of the leg work.
    Needleworks - you need to make another 3 or 4 more. People see them sitting on a flat surface and can't help picking up a tile, turning it round, and dropping it back in somewhere else. At least, they do with my Escher reptile-based design, and I can't see why these shouldn't work as well.
  6. Quote Originally Posted by needleworks View Post
    Very nice! The first ever trispokedovetiles to make it off the drawing board into real life!
  7. TRISPOKEDOVETILES ROUTER CUTTING
    My trispokedovetile CAD-CAM webpage now offers an (X,Y,Z) option for router cutting using rotary tool paths between spaced out tiles -
    I've simulated the CNC router code -
  8. #28
    Excellent!
    It now merits the designation CAM ;-)
    - Nick
  9. The Following User Says Thank You to magicniner For This Useful Post:
  1. A little bit of G code help please!
    By njhussey in forum Programmers Corner
    Last Post: 16-11-2015, 03:36 PM
  2. Anyone got some 2.5D G-code please ?
    By dudz in forum Programmers Corner
    Last Post: 22-06-2013, 11:21 PM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  4. Spoke to some timing belt companies, intersting stuff........
    By psiron in forum Belt Drive, Pulleys & Timing
    Last Post: 23-09-2010, 03:51 AM
  5. G Code help
    By moose007 in forum Programmers Corner
    Last Post: 22-05-2009, 11:39 AM
