    Just came across this and thought it may be of use to people looking at machining their own ballscrews, it shows the 'standard' threads and bearing dia's. -
Name:	machining 1100mm small.jpg
  2. The Following User Says Thank You to HiltonSteve For This Useful Post:
  3. #2
    Not nicked it, just borrowed it.....
    I will put it back when everyone has finished looking at it.:naughty:
  4. Oi thats mine, thief, call the police.
    These ones are better.
    Attached Thumbnails Attached Thumbnails 9B1806 (R16-05T3-1-FDUD-519-600-C7-R-P1).pdf   9B1803 (R20-05T4-1-FDUD-1417-1500-C7-R-P1).pdf
  5. #4
    OK, its a fair cop...!!!!
    Best have a look at the better drawings before they take me away.:sad:
  6. #5
    Quote Originally Posted by Gary View Post
    Oi you motherFunkie !
    .Me
  7. #6
    m100's Avatar
    Lives in Yorkshire, United Kingdom. Last Activity: 15-06-2023 Has been a member for 9-10 years. Has a total post count of 10.
    anyone have something similar for 12mm ballscrews?
  8. #7
    No but I do have some 12mm ballsrews that I could measure for you...
    Not tonight though as after too many pints the tolerances get wider...
  9. #8
    Hi
    Marchant dice have some dimensions at http://www.worldofcnc.com/images/Machining.pdf
    although it appears that things have moved on the thread front in that the one I got from them had an m8 x 0.75 thread.
    A finer than the m8x1.0 on the list which meant more expense buying a tap and die which I had to buy as the other ball screws did not have the ends machined.
    Peter
  10. Here you go.
    http://www.slidesandballscrews.com/p...ages 63-64.pdf
    Quote Originally Posted by m100 View Post
  11. #10
    m100's Avatar
    Thanks, much appreciated!
  1. WANTED: Ballscrew and nut
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 04:25 AM
  2. Aluminium Warehouse contact details
    By m_c in forum Marketplace Discussion
    Last Post: 09-08-2013, 09:31 AM
  3. RFQ: Machining mounts in 80x40 profile for FK ballscrew supports
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 20-03-2012, 12:49 AM
  4. Where to get C3 & C5 Ballscrew
    By AdCNC in forum General Discussion
    Last Post: 10-08-2011, 06:56 PM
  5. Machining Ballscrews with a mini lathe (& ballscrew support questions)
    By HankMcSpank in forum Lead Screws, Nuts & Supports
    Last Post: 16-02-2010, 12:22 AM
