Page 1 of 3 123 LastLast
    Hello,
    New guy here and glad to be part of this forum.
    I'm in possession of a GH1440 Lathe Bed + Headstock + Tailstock (a quite rigid base I would say) and I'm willing to convert it into a CNC lathe + 4th axis Router/Mill. Will be used for Al alloy, steel and perhaps some plastic, for hobby and prototyping (max 50mm O/D parts, but occasionally bigger O/D parts as well). Ideally, I'm willing to achieve 0.01mm tolerances.
    I've got a lot of unanswered questions as you can imagine, but at the moment I cannot decide how to proceed with the lathe spindle, which will be the 4th axis as well. To make it simpler, I was thinking to design it to be able to mechanically switch between the lathe and the 4th axis mill. So the first question is what motor should I use for the 4th axis / lathe spindle? I was thinking to go for a high torque NEMA34 hybrid stepper (servo stepper) but I calculated it wouldn't give me much RPM for the lathe spindle (about 300RPM). How much RPM would I need anyway, given the parameters? Would I need 2 different motors instead, one dedicated for the 4th axis and another one dedicated for the lathe spindle?
    Anybody who finds a free minute is more than welcome to suggest/advise anything.
    Many thanks!
    Hi, I know nobody answered, sometimes I ask stupid questions.
    But do you find the speeds for the lathe fairly accurate in the *.pdf bellow?
    http://gradstudentshop.usc.edu/assets/001/64641.pdf
    LE. I was thinking to use this servo stepper as a lathe spindle motor. Do you think it would suit the application?
    http://www.ebay.co.uk/itm/EU-STOCK-N...wAAOSwKOJYIDqI
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    For that size lathe, I wouldn't personally got for anything less than 2HP for the spindle for turning.
    For a 4th axis, that's where things get tricky. Even with a large servo, by the time you gear it to get 2-3000rpm, you end up with very little holding torque for doing accurate positioning work.
    And not only that large servos are expensive. This is something I've often though about, and for ideal use, you need some way of changing servo:spindle ratios, so you can have one high speed low torque ratio, and one low speed high torque ratio. The problem is how to achieve that while minimising backlash.
    Thank you for the reply m_c. Good points.
    My thoughts were to use 2 separate motors, and couple them both to the spindle: one geared up and the other geared down. But only one would be powered on and running at a given time. At the same given time, the other one would still be rotating, but driven by the spindle (as it won't be powered) - the spindle would rotate due to the other one.
    I would create a lathe profile (in Mach3 for instance) and run the machinery in lathe mode, with the high RPM / low torque servo power on (and the other servo off).
    When milling is needed, I would shut down everything, create another profile (mill profile) and run the machinery in milling mode only, but this time with the low RPM / high torque servo powered on (and the lathe spindle servo off, which would still be rotating due to the other motor), configured for the 4th axis role.
    The lathe and mill would share the X and Y axis steppers.
    I hope it makes sense.
    Do you think I'm going on the right track, or talking bananas?
    Hi Valfar
    Bananas for sure.
    Get a mill for milling and a lathe for turning. Even a small benchtop mill is better than what you are trying to do.
    Also, for a lathe , there is no need for a servo spindle, just install a indexing pulse to tie every thing together. Then with a nice 3phase motor on a VFD you can do all you need to do.
    Regards
    https://emvioeng.com
    Hi Komatias, thank you for the input.
    I'm sure there are lots of things better than what I'm trying to achieve, but in my view it all goes down to what one's able to compromise, like every single bit in this life. I think everybody agree a lathe/mill combo is not a new concept. That being said, I don's see a problem with the design idea. The challenge would be how it's implemented. I now need to understand what's wrong with my approach.
    I understand a VFD + 3 phase motor would work similar say to a 3kW spindle found on the ebay, but also add an indexing pulse into the equation. Is that correct? Is there any VFD/motor you would recommend for a DIY application, or does any reasonable priced ones bought over the ebay would do the job?
    Cheers!
    Valfar,
    Are you looking to make money from your machine or are you just doing it for a hobby? If you are planning to make money, do not be cheap.
    Any lathe has been designed to take cutting forces in the direction that causes the saddle to compress against the bed ways. Even the machines that have a milling head on the top of them take forces in that direction. Using the lathe spindle to mill causes a torque which compresses the one side of the saddle while lifting the other side. Not very good for the saddle clamps and will undoubtedly make milling a pain in the rectum.
    Myford users get away with it because they only take light cuts. With the 1440, it would be a waste really.
    Yes, you are correct in the watercooled spindle comparison, only difference is that the lathe spindle motor can be 2.2kw and have lower RPM, thus higher torque ;)
    Komatiad, my understanding is the spindle would become an A axis, with a separate milling head bolted on elsewhere.
    Quote Originally Posted by Valfar View Post
    That wouldn't work. Say you have the low speed with a 10:1 ratio, and the high speed direct drive, that would mean at high speed the low speed motor will be getting driven with a 1:10 ratio, so at 3000rpm, it would be doing 30'000rpm.
    There is a Swapaxis function within Mach3 that you probably want to look at.
    If you've not already seen it, you may want to have a read of this thread - http://www.machsupport.com/forum/ind...c,11422.0.html
    A possible option, depending on if you don't need the 4th axis to move while machining, is to add a brake, as then you don't need lots of torque to hold the spindle. You just need enough torque to locate the spindle, then use the brake to hold the spindle.
    Morning!
    The only major compromises I'm making is the compact size of the machinery, and the lathe + 4th axis mill combo. Have already gotten the bed + headsock + tailstock. From here, will definitely won't go cheap. It will be used mainly for hobby, not production, but you never know. I need to bring to life a few design ideas I have.
    M_c is right, the lathe's spindle won't be used as a milling spindle. The lathe's spindle will be used as a 4th axis when in milling mode. Another spindle (perhaps an ordinary 3kW water cooled spindle off ebay or a better one - no idea yet) will do the XYZ operations, similar to what a conventional milling machine does. But it will all be much clearer when I'll have a 3D model ready to show you.
    I'm not yet familiar with Mach3 and with the low level programming. At work I'm using an industrial 3 axis router, and software like Vectric / ArtCAM (you get the idea). Will definitely look into the 'Swapaxis' function, thank you for bringing it into discussion.
    I was aware of the brake system design for a 4th axis. But my thoughts were to use the 4th axis simultaneously. The brake could be added as an option though, when only one face would need machining. But it adds to the complexity, and I'm trying to keep it as simple as possible. Wouldn't a geared 12Nm Nema34 do the job without a break? I don't need high speed & feeds. I will consider a brake if it doesn't.
    Also, good point m_c about the low speed motor driven by the other one at extremely high RPM. Haven't thought about it. That means the lathe motor (the 2.2kW low RPM komatias has been suggested) can be permanently attached to the spindle, and a servo (hybrid) stepper would need somehow to be detached when in lathe mode.
    I see this guy nailed it. He made a lathe and a 4th axis mill run simultaneously. I'm sure you are well aware about his project.
    https://www.youtube.com/watch?v=b2-Kdud7eiA
    And with a single motor attached to the spindle. What's the catch?
    Plenty of homework for the week-end.
    Thank you for your time. You guys are great!
    I am perhaps the only one with experience, who has done this, so...
    At this time, after 3-4 trials, I have a 2.5 kW AC brushless servo as the spindle drive, at 1:3 belt drive, via HTD 8-30 belts, on a very strong, sturdy, rigid frame of approx 60 kg mass.
    So I get 0-1000 rpm, with a C axis or "live cnc spindle".
    Servo is 10.000 counts at 1:3 belt drive for 1:30.000 counts at spindle.
    This is not rigid enough for milling.
    And my 600€ belt drive 30 mm wide, 8 mm profile, taperlock pulleys, 24:72 teeth at spindle, setup is very, very industrial, so...
    The setup is excellent for turning and lathe use.
    I get 90 Nm at spindle.
    Spindle motor is 10 Nm cont, 30 Nm peak (3 secs) x 1:3 = 90 Nm at all rpm.
    I will use it as-is, until I switch to a secondary, likely a (double) worm drive or planetary at 1:10, at some point.
    My experiences, working at this for 10+ years.
    Steppers are no-where near accurate enough.
    Even the best belt drives are not accurate enough.
    HAAS uses a gear on the spindle, for C axis use.
    But they use a class 9 ultra-precision gear for the C axis, only, switch it in-out, and the gear grinder cost 9M$, I have met the guy who sold it.
    So my system is better/similar to simpson of cubestudio, and not good enough in rigidity for C axis.
    I use a bigger/more accurate servo, and similar/bigger belts (his are also HTD-8, I think mine were wider).
    And my lathe is a 12x, fwiw..
    Hth.
  1. Stepper and Drive sizing for Lathe Conversion
    By Robotwizard in forum Stepper & Servo Motors
    Last Post: 17-08-2016, 01:38 AM
  2. 9x20 lathe conversion, pointers wanted
    By Stupoty in forum Gantry/Router Machines & Building
    Last Post: 31-12-2014, 08:40 PM
  3. Sieg mini lathe cnc conversion need help
    By diddly in forum Sieg Lathes
    Last Post: 20-12-2014, 10:53 AM
  4. Seig C4 Lathe CNC conversion
    By njhussey in forum Sieg Lathes
    Last Post: 11-04-2014, 06:40 PM
  5. Micro lathe Zero backlash* conversion
    By Jonathan in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 22-09-2012, 10:56 PM
