19-05-2018 #301
19-05-2018 #302
19-05-2018 #303
Hah thanks guys. Either going to anodise or powder coat, both should keep it looking nice through some gentle abuse!
Little micro update (been busy barbecuing today!)
3D printed a mount for the homing switch magnet and fitted. To set the activation range I just hooked the switch up to 24v and moved things around until the LED switched off at the right place.
20-05-2018 #304
More work done today... Didn't have any suitable materials for the counter bearing plate so got cracking with some of the other stuff!
First up, 6mm spacer for the ball nut mount to make it reach the front plate:
And then on to a big piece (so big it takes up most of my poor little X6's bed!) - the front mount plate
Externally clamped and all the interior parts done
external clamps removed and finished part:
Fitted along with the previously printed plugs. Other large hole will be for ball nut grease port which I'm currently working out the finer details of.
Full up:
Full down:
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
24-05-2018 #305
Decided to re-vist my original plans for a belt tensioning system.
I whipped up this design
And then set about making it. The idler I made from alu tubing which I turned down and bored out for the bearing pockets.
I also needed to make the upright piece which the whole assembly rolls around. Turned this from silver steel:
Final part that needed turning was the little rotating piece through which the threaded rod will go... Made a small jig to make sure I drilled it centrally, which could also then be flipped and guide the tap straight through.
I decided to try 3D printing the main parts in the CF composite material I use for functional parts and I must admit I was amazed at just how strong it's come out. I upped the infill percentage and used extra perimeters to beef up the part even more and the result feels like it could survive being run over by a truck... my backup plan was to make the frame parts from alu plate but it won't be needed.
Even more surprising is that I modelled the M6 thread in the bearing tube mating part and it printed fully functional... didn't even need to run a tap through it. That's the smallest thread I've tried printing so far and I'm suitably impressed :)
Final bunch of parts:
And test fitting
Untensioned:
Tensioned (can't fully tension for two reasons - screw thread isn't long enough, and the smaller pulley pulls in towards the bigger one without the top bearing counter plate.... but it gets the gist across):
Pretty chuffed with that little bit of design I have to say... worked out nicely. Still need to make a knurled knob and order some m6 threaded rod to make the proper tensioner adjustment, and I also need to make the little collar that goes on the m5 standoff to help capture the rod end.
24-05-2018 #306
It is very OTT but you look like you are having fun so go for it!
How about 3D printing the adjuster knob - put an internal thread in it and secure with a lock/jam nut.
24-05-2018 #307
25-05-2018 #308
The Following User Says Thank You to Chaz For This Useful Post:
25-05-2018 #309
The Following User Says Thank You to Snapper For This Useful Post:
25-05-2018 #310
This is all looking very nice and a really wonderful build!
Would you care to share the Fusion files of the Z-axis only perhaps...? :-)
Cheers - Ard
The Following User Says Thank You to AVF For This Useful Post:
There are currently 16 users browsing this thread. (0 members and 16 guests)
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
