The Following User Says Thank You to A_Camera For This Useful Post:
13-02-2017 #2
I can see where the advantage is, in that the gantry arms can be a fair chunk shorter and thus give more rigidity for a given thickness.
The disadvantages are that it's a potentially a more complicated mounting assembly (especially when ball screws are considered as well), would need extra work to add shielding for the rails and would end up eating into my X-Axis bed area (although actual work area would probably be able to be kept the same with a little careful work, there would be less room for overall material size and clamping.
So the question is whether I go on the basis that 25mm thick plate will be sufficient for the gantry arms at their current length, or whether I want to take those above mentioned compromises in order to gain a little extra rigidity.Last edited by Zeeflyboy; 13-02-2017 at 11:37 AM.
13-02-2017 #3
Bit more time refining the new Z-Axis design.
I realised I needed the plate that slides down to be slightly slimmer than the unit as a whole, otherwise it would jam on the water/chip tray sides when in the lowered positions so tweaked that along with some more design details and seals, tramming plate etc.
There are currently 21 users browsing this thread. (0 members and 21 guests)
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
