27-04-2017 #121
27-04-2017 #122
Well you can't make a square hole with a round bit, so if you need it more square use a smaller bit.
27-04-2017 #123
28-04-2017 #124
28-04-2017 #125
30-04-2017 #126
Not perfect but I think I have got it down pretty well.
I don't have a 3D probe yet so whenever I reset the machine I am obvious out somewhat.
The last operation of cutting out the case was well out for some reason..
I am working now on setting up a spoil board underneath the stock to then super glue my stock to.
This means I am not cutting out something floating in mid air.
Just another bit of aluminum stock will do that I can then glue my work stock onto with super glue?
30-04-2017 #127
Well superglue worked really well.
Surprised how quickly the two bits stuck together as soon as I got the air out of the gap.
Much better than cutting in the air.
Main problem atm is the water.
Thinking of building a dedicated table for the machine which is basically a drip tray that I can then have doors on each side and all the stuff bellow like the controller, spindle cooling res, cooling water etc.
Means I can flood cool too. Which will be quieter than using the air compressor.
Thoughts?
02-05-2017 #128
We are cutting steel on mills with mist so not to use coolant and you are going backwards. Cooling with liquid is nice for a production setup but for home? The less, the better. Mist is better for home. Do it properly as i have made it and there will be no problem. With one nozzle you can cool up to 25mm bits.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
03-05-2017 #129
Thinking about it you are right.
Going to make a bed for the CNC that can hold the water that comes off the mist.
I actually had the bottle about a meter above the cnc the other day and just the water alone worked fine by the looks of it.
No air just gravity fed water.
Anyone tried these?
https://www.shop-apt.co.uk/corner-ro...ide-45hrc.html
There are 2 Flute ones but only in the US from the looks of it.
I need to put a nice round edge on my product housing and these look to be the only thing available.
03-05-2017 #130
Anyone tried these?
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
