Thread: Problems with Lucy
04-03-2017 #1
So I finally have Lucy set up and read to go.
Yesterday i was doing some test cuts on some 10mm foam board i had readily available.
I quickly drew up a file with 6 circles that sit within each other, and for the CNC to cut various steps into the foam board, then finally cut the circle out of the board.
Circle Depth Radius Circle 6 8mm 20mm Circle 5 6mm 40mm Circle 4 4mm 60mm Circle 3 2mm 80mm Circle 2 1mm 100mm Circle 1 11mm 120mm
Should look like this:
See the attached Aspire file, dxf and file for Mach3 txt file: CNC Test-20170304.zip
I set the feed rate to 100 mm/sec and 8,000 RPM
Anyway, everything looked file until it got to the outer circle (circle 1), when it did this (I set it to do 11mm, so all the way through)!
Does anyone have any ideas why it did such a crazy thing?
EDIT: Uploaded correct Mach3 file: CNC Test-20170304.txt
Just as a reminder,
I have a 1m x 1m,
Dimension: 3 + 1 (mirrored)
Drive type: BeltLast edited by CrazeUK; 04-03-2017 at 03:18 PM.
CNC problems
By martythunder in forum General DiscussionReplies: 1Last Post: 15-02-2017, 08:10 PM -
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
