    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 4 Days Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Hi All,
    I moved to New Zealand 5 years ago. My belongings inc my CNC router only arrived recently . Now I'm set up again but totally out of practice and forgot a lot that I need to teach myself again. I was no expert to begin with but Ok for being self taught.
    I run Mach3 .Version R3.043.062 I have an issue I remember having last time I used it that I need to sort before I start again. Maybe simple ?.
    In the middle of milling product, if I notice something is not quite right with the toolpath or I need to pause the program momentarily, I use FeedHold. As I understand it, after I want to continue the process I press Cycle start again. But then something disastrous happens and the spindle moves or jumps to a different part of the nc file and the tool crashes into the vice or other part of the product . Un-related to where it was left off. Maybe I have a setting in Mach3 ticked or un-ticked that is causing this?
    Also another small issue was my nc file and mach3 had conflicting Safe Z points. What is the simplest way to keep this a standard ? Keep the Safe Z dictated in Mach3 or in the .nc file ?
    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 30-12-2022 Has been a member for 5-6 years. Has a total post count of 116. Received thanks 16 times, giving thanks to others 21 times.
    Not sure if this may be of any benefit for you but when I cycle hold I always restart it from a known safe point such as a straight line or Safe z so I know it wont plunge into stock by accident. A pain but I think there is a better work around from the more knowledgeable wizards on here!
  1. NCStudio to Mach3 question for a chinese 3020 router
    By Fivetide in forum Chinese Machines
    Last Post: 11-04-2015, 10:37 PM
  2. How would you fasten back to back carriages?
    By CharlieRam in forum Rails, Guideways & Bearings
    Last Post: 04-09-2014, 11:01 PM
  3. angular contact bearings - back to back, further apart
    By dsc in forum Linear & Rotary Motion
    Last Post: 05-01-2014, 10:59 PM
  4. Mach3 Easy Question For The Experienced
    By Carlb1058 in forum Artsoft Mach (3 & 4)
    Last Post: 08-04-2013, 09:48 AM
  5. 5 Years in! here goes my build
    By cncezee in forum Milling Machines, Builds & Conversions
    Last Post: 03-03-2010, 11:49 PM
