Thread: making a non-spill oil pot
11-03-2017 #1
Made one of these the other day:
I'm not the first to make one of these but thought it looked like a good idea. CNC4XR7 posted this video, which he saw on mrpete's channel
https://www.youtube.com/watch?v=gj-upkW8rhQ&t=97s
I've knocked over my current oil pot more times than I remember so something had to be done. I found a few plastic non-spill containers, but they didn't appeal. So I started looking at aluminium water bottles on ebay, about £5 from China. Then by chance saw this for 50p at our local recycle centre:
I did a few calcs and decided on taking ~40mm off the top, and cutting the base down to ~70mm. This leaves about 20mm clear when the top is inverted and pressed into the base.
Chucked it up in the lathe, running at about 100 rpm and taking it easy. The nose of the chuck made a nice gentle steady. The last bit when it broke through was a bit perilous:
I cut the base down to ~70mm using the parting tool to get the cut going then finished off with a hacksaw, and then finally I used the normal LH cutting tool to tidy the edge. The bottle is very weak during this bit and it kept moving away from the tool, plus it jumped out of the jaws more than once so be careful. No photo of this bit.
Finally trimmed it down and pressed the top (inverted) into the base. As it was a very tight fit I couldn't push it down far enough to roll over the raw edge, so just cleaned it up so I didn't cut myself on it:
Wondered if the original lid would fit in the thread - and it did! This will keep bits out when not in use:
I've not filled it with oil and tried the non-spill action yet but should be OK.
Making a Die?
By Tenson in forum General DiscussionReplies: 11Last Post: 06-01-2021, 09:44 AM -
NEW MEMBER: Hi I'm new to making Cnc machine
By Jeromep in forum New Member IntroductionsReplies: 1Last Post: 24-09-2016, 04:35 PM -
NEW MEMBER: My first go at making a CNC router
By Norgmonster in forum New Member IntroductionsReplies: 23Last Post: 26-06-2016, 01:31 AM -
Making a little box
By mark84 in forum General DiscussionReplies: 5Last Post: 11-03-2014, 11:34 PM -
Making a Jig
By Wobblybootie in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-06-2010, 11:17 AM
