  1. #31
    Look slike you have no speed set so it's running but at Zero speed.
  2. #32
    Ok gimme a min to wire up as per pic
    Sent from my iPhone using Tapatalk Pro
  3. #33
    Quote Originally Posted by D-man View Post
    So wire up as per picture and change parameters you mentioned and also accel ?
    Yes if it starts then try lowering the Accel until it doesn't. Usually around 4-6 will work ok but depends on spindle.
  4. #34
    Ok it's doing something. It's controlling via the software but not firing up
    https://youtu.be/98LXdpYtOTw
  5. #35
    have you typed speed in try using MDI and type M3 s12000
  6. #36
    Yeah, just turns the VFD fan on but no spindle etc
  7. #37
    Should I turn the other wires off in the VFD, maybe it's looking for those?(Green/red/yellow )
  8. #38
    if this doesn't work then you probably not got voltage coming out of the eding so test voltage. @ s12000 you should have around 5v
  9. #39
    ring me if still got number
  10. #40
    Ok Guys had a bit time to revisit this. Your help would be very much appreciated.
    The above options don’t work, however after a bit of fiddling, UV managed to get the spindle to switch on and off with the software.
    My question is, what will control the speed? I’ve got 0-10v coming from the PWM and increases when spindle speed on the pendant wheel.
    I’ve tried connecting to AC1&2 and also VC1&2 with no luck. I’m guessing it’s a setting in the VFD but I can’t see it.
    It’s also worth mentioning that if I put PWM to X1-2-3 or 4 I get a separate set speed on each.
    Please help guys, half way there!
    https://youtu.be/b2cbv0fuKj4
  1. FOR SALE: Eding cnc controller
    Last Post: 01-08-2016, 03:31 PM
  2. Eding cnc
    By Ben-bee in forum CAD & CAM Software
    Last Post: 17-05-2016, 08:48 PM
  3. Setting ADTECH servos with Eding CNC software steps/AppUnit
    By D-man in forum Stepper & Servo Motors
    Last Post: 24-04-2016, 02:50 PM
  4. CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
    By Soren DK in forum Conversion Build Logs
    Last Post: 11-04-2016, 08:40 PM
  5. Eding CPU5A4E controller and Siemens G110 VFD.
    By calgone in forum EdingCNC (CPU5, CPU5A)
    Last Post: 06-02-2015, 11:31 PM
