    A syil power drawbar. Couldn't find a suitable one given the space. Thought you might be interested in how this turned out. Works really well.
    Shout if you want access to the CAD files.
    Best,
    Pete
    Quote Originally Posted by petemilligan View Post
    Best,
    Pete
    Hi Petemilligan and welcome to the forum. Would you mind put some more pics up of how it works if it is using spring etc. If possible Thanks
    Sure, Here you go...
    & Video
    Hi Pete, after the sad demise of my coventry easy change adaptor, im now looking at other quick change tool syatems for the Syil. I dont suppose you still have the cad files?
    Quote Originally Posted by Benja View Post
    I do. Using Fusion?
    Pete
  7. The Following User Says Thank You to petemilligan For This Useful Post:
  8. #7
    I am
    .Me
  9. #8
    I do. Using Fusion?
    Pete
    Fantastic! :D I am as it goes
    Is it any old butterfly wrentch or a specific brand/type?
  10. #9
    • Standard old butterfly. You have space & might want to beef up the air piston from the small one I have.
    • Find a 12 point socket for the drawbar.
    • Air plumbing (in my case) used 3 air solenoids.
    • The long strip in the design suits a limit switch to start the wrench.
    • Cut an internal relief for the piston clamp
    • Source a couple of linear bearings for the wrench plate travel
    • The bars were silver steel (what I had in stock at the time), they're holding up fine.
    https://a360.co/2J9wMhg
    Hope this helps.
  11. #10
    Hope this helps.
    Thats very good of you. thank you :) couldnt understand what you meant then for a sec - so a roller type limit switch will start the wrentch as the piston ends it stroke ? I pretty sure ive got it.
  1. syil x4
    By geoff in forum Machine Discussion
    Last Post: 30-11-2016, 07:35 PM
  2. KX1 Drawbar too long?
    By mbcx4jrh in forum Sieg Milling Machines
    Last Post: 17-09-2016, 05:42 PM
  3. DIY Spindle Drawbar?
    By Chaz in forum Spindles & Drive Motors
    Last Post: 15-09-2016, 03:55 PM
  4. Budget Power Drawbar
    By needleworks in forum Milling Machines, Builds & Conversions
    Last Post: 17-12-2015, 11:36 AM
  5. Warco Drawbar woes...
    Last Post: 22-12-2008, 12:56 AM
