  1. #41
    Hi John the meter readings are all zero on that side switches open or closed
  2. #42
    Hi Kev
    I think a simple tester would prove if the breakout board is working
Name:	bob limit switch tester.jpg
Name:	breakout board input tester.jpg
    John
  3. #43
    John can I send you the board ?
    You know way much more than I do about this kind of stuff
  4. #44
    Hi Kev
    OK
    PM sent
  5. #45
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    John, I suspect you've got the optos in the wrong order.
    If you look at the traces on the top side, I'd say the top opto is P10, and it's track runs down the outside of the limit switch connector to the E-Stop connector. The tracks of the other 4 optos seem to match up nicely with the Limit Switch connector, and I wouldn't expect the bottom opto track to run the way it does if it was going to the E-stop connector.
  6. #46
    Hi m_c
    from post 45 "John, I suspect you've got the optos in the wrong order"
    you are correct
    now I have looked more closely
Name:	Limit Switch tester & partial TX14175 circuit.jpg
    during the last few days I have installed mach3 on 3 PC's
    IBM thinkcentre , Dell optiplex 755 and a PC built using a ASUS H110M-R motherboard
    so I should be in a better position to test Kevins mach 3 settings
    John
    PS
    as I can't upload a PDF data sheet on DC to DC converters
    a link can be found here-
    http://uk.rs-online.com/web/p/isolat...rters/1914922/
    Last edited by john swift; 06-04-2017 at 12:56 PM. Reason: add PS link to RS Components for DC DC converters
  7. #47
    Hi...as per my knowledge when the limit switch is closed, the EL817 opto isolator's NPN transistor will ground the printer ports input pin. The breakout board does not have any pull up resistors to ensure a printer port input is at a valid logic high when the limit switch is open.
    assembly circuit
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Another Home - Limit switch question
    By Cube3 in forum General Electronics
    Last Post: 26-12-2013, 07:51 PM
  3. Limit and Home Switch Choice
    By Wobblycogs in forum General Electronics
    Last Post: 02-12-2013, 06:16 PM
  4. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
  5. bounce off home switch.
    By motoxy in forum Machine Control Software
    Last Post: 30-08-2012, 12:26 PM
