Thread: Losing steps on Z axis
29-03-2017 #1
Ok so, a couple of weeks ago i changed my stepper driver to a totally different one that was in it.
Yesterday I tried doing a halftoner tool path (loads of z movements)
Halfway through i notice hey this looks abit deep here. So i checked and i had lost like 18mm. So ok i zero and try again. Same thing happens.
Run a profile cut today on some small items and i lost 2mm
I have tried decreasing acceleration and velocity on the z axis in Mach 3
This didn't work.
Checked all set screws and bolts on z everything is tight.
Is this just totally the wrong driver or what is happening here it is driving me bonkers please help.
29-03-2017 #2
29-03-2017 #3
Had a similar problem when I set up my new router. Checked all mechanical components, made sure no slippage anywhere. Still lost z position. Not sure how your drivers are connected but I would double-check polarity of step signals between BOB and driver. When you changed the driver, did you also have to make any changes in Mach3 (or other motion control software) - like step signal polarity or z direction? That was my problem - driver is triggering on wrong edge of step pulse and the end result is that you lose one step every time you change direction. Doesn't really show up on a simple xy profile cut but once you get a lot of z movement, that's when you see the effects. If that is the problem, fix is very easy.
So, how's the driver connected, and did you change anything when you swapped drivers? What were old and new drivers?
30-03-2017 #4
As Neale says, it does sound like a step/direction timing issue.
What make/model are the old and new drivers?
What controller are you using?
If you're not sure, post up some pictures.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
30-03-2017 #5
Hello, yes i had to change the direction when i put the driver in the previous was a leadshine DM856 and the new one i put in was one from cnc4you
Cwd556. Now what i will say is I did have to change the steps per unit but nothing else was changed. From changing the driver what i did notice was the sound of the z going up and down was considerably louder?
30-03-2017 #6
I understand that you are using a CSMIO motion controller. In all other respects, this is a good thing - I use one myself! However, assuming that it uses differential signalling to the driver (which is also a good thing) then it is very easy to get, literally, your wires crossed. Quick way to check is to go into Mach3 -> ports and pins -> motor output and click the Step Active Low box (changes from red cross to green tick). This is exactly equivalent to swapping the wires between CSMIO and the driver. Just do this for Z, if the other two axes are OK. Then do another test.
This is my red-face moment - despite working very carefully, when I wired my control box I managed to get these exact same connections swapped myself. However, as I say, if this is the problem (no guarantees but it sounds very familiar) then this will fix it. Then you can go back and recheck your "steps per" settings as these might have been affected by the problem. If this is not the problem, then nothing bad will happen and you can put the Mach3 setting back as it was and look further for the problem. However, this is so easy to do and check that it's worth taking a few minutes to try it first.
30-03-2017 #7Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
I don't know the DM856 or the Cwd556, but if you are using CSMIO then I think one problem can be the pulsing frequency. If I am not wrong, CSMIO is capable of running much faster than 200kHz and most drivers can only handle maximum 200kHz pulsing. Perhaps that was not an issue with the DM856, but may be an issue with the Cwd556. I know I can run my DQ542MA at 400kHz, even though they are also only for 200kHz, but since I occasionally experienced some issues when I ran them outside the specs, I reduced back to 200kHz and my problems were gone. So, have a look at your pulsing frequency and reduce to 200kHz if set higher. Also check the specs of Cwd556 regarding this, and keep your pulsing at or below that level.
30-03-2017 #8
30-03-2017 #9
Although it is capable of high pulse rates, there isn't any control on the CSMIO to limit max pulse speed. However, this doesn't matter. Pulse rate is decided by how fast the motor turns, and how many steps per rev. So, 5000mm/min axis with 5mm lead ballscrew means motor turns at 1000RPM (assuming direct or 1:1 belt drive). 200 steps per rev with 8x microstep setting (pretty typical) gives 3200 microsteps/rev, that is 3200 pulses/rev. So, that's 320000 pulses/min, roughly 5300 pulses/sec. Well within the capabilities of any of the usual drivers. It is possible for pulse rates and wait time between dir and step pulses to be a problem in some systems (e.g. where you can change pulse length) but these are fixed in the CSMIO firmware and seem to work well. I can't think of an obvious reason why you would want to pulse a stepper much faster than this; usually the reason for needing faster hardware is to cope with encoder pulse output from servo systems rather than open-loop steppers.
30-03-2017 #10Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
8x microstep = 1600 pulses/rev, not 3200... your steps per mm should be set to 320. Am I wrong about this?
Here is how I calculate this for my machine:
In my case, my machine is capable of 8000mm/min on each axis, though I limited the Z to 6000 mm/min. If all axes are moved at the top speed, that means a total of 22000 mm/min, which is equal to 366.7 mm/sec. Each mm requires 400 pulses (2000 per rev), so that speed requires 146666 pulses for all axes maximum speed, which is OK, since my drivers are capable of maximum 200 kHz. BUT... if I had dual screw on one axis I'd be driving with a total of 30000 mm/min, which is 500 mm/sec which would in my case require 200000 pulses and which is the maximum limit of my drivers. OK, I could change micro stepping to solve that, but never the less, it would make a huge difference.
The pulsing (kernel) frequency means that the (positive or negative) pulse width is equal (1/f)/2 => 2.5us for each pulse, regardless of the speed, if the frequency is set to 200 kHz. Of course, if I'd set my UC300ETH to 400 kHz kernel then I'd get 1.25 us pulses, and the opto couplers may not be able to cope with such short pulses, which is what I noticed. when I tested it out.
Never the less, of course if your speed is limited to 5000 mm/min on each axis then you have 15000 mm/min total speed, which is 250 mm/sec and that should be equal to (in your case) 320 x 250 = 80000 pulses/sec (80 kHz) so there is a large margin. But I don't know the CSMIO, so I don't know how that is generating pulses. I thought it works similar to the UC300EHT and you can set the kernel frequency.Last edited by A_Camera; 31-03-2017 at 07:25 AM.
Router losing steps. Solution needed. Will this help?
By cncbobuk in forum Chinese MachinesReplies: 9Last Post: 27-12-2017, 03:40 AM -
New Mill losing steps
By lukecnc2012 in forum Gantry/Router Machines & BuildingReplies: 42Last Post: 08-11-2014, 02:56 PM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM
