Thread: Mysterious Z axis errors
30-03-2017 #1
Hi everyone,
Started routing a piece of plywood using UCCNC, with a cut that is uniform and parallel from end to end, to find that my Z axis is loosing position as it moves along the piece.
The first time I was running constant velocity mode, with max acceptable error of 30 microns. I ran 95cm in length, the Z error was actually to push the Z axis into the piece further ( create a deeper cut ) , and over 95cm, I had a change in Z position of about 1 to 2mm deeper cut.
The second time, I changed the constant velocity mode max error to 50 microns, decreased the Z axis max acceleration by 60%, and max speed to 30% to discount the motor missing steps due to load at higher speed/accelerations. This time the Z errors appeared to occur much faster, and after about 20cm, the Z had plunged down an extra 4.5mm.
The G-code is correct, and I confirmed that without running the program, jumping from start to finish showed that the work was 4 to 5 mm deeper at one end vs the other.
My thinking is that it somehow has something to do with Constant velocity mode ( although this is not supposed to create compound errors, just errors between point a and point c ) - or my controller not hacking it, or not providing enough holding power sometimes ( G540 )
The wierd thing is, when I slowed down the z axis and accelerations, it got worse - which you would think would make better if it was a load related issue?
Still wainting the leadshines to arrive, so need to persist with the G540 for now
Any ideas?
Nick
mach3 csmio ips errors
By Web Goblin in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 07-01-2017, 10:47 PM -
Axis scaling errors - is this just to be expected with C7 screws?
By GND in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 23-11-2016, 11:19 PM -
Motorcalc spreadsheet errors
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 10-03-2015, 07:02 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
