15-06-2017 #41
A dedicated supply is obviously the gold-plated solution but I'll think you'll find that pretty much everyone with a similar machine runs the machine off a single 13A socket. I use a 4-way adaptor for control box, inverter, and PC all going back to a single wall socket. No problem at all. Don't be misled by the inverter rating. That's max output power and it's unlikely that you will be pushing it that hard, if ever. Run the vacuum cleaner off a second 13A socket but loading is fine even if it is the same ring. In other words, you could swap a single 13A for a double and still be ok. Even if not a ring and single socket is on a spur, I believe that that should be good for 20A/5KW total load (but would need double socket).
No allowance for kettle in that, of course! Sure it's only 1KW?Last edited by Neale; 15-06-2017 at 08:07 AM.
15-06-2017 #42
In reality your spindle will never pull 2.2kw on a machine with this level of rigidity... most of the time it will be much lower.
Your stepper motors etc also are incredibly unlikely to all pull peak power at the same instant.
I do exactly as neale said... I have everything running off a dual socket (computer, monitor, compressor on one, CNC on second) and i run my vac from another socket (which just so happens to be on a different ring, but would be fine on same ring).
Obviously if you want to give it a beefier supply then go for it, but it's not necessary imo and doesn't really fit with your cheap as chips goals!Last edited by Zeeflyboy; 15-06-2017 at 10:58 AM.
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
15-06-2017 #432. Run a dedicated 32amp 5 wire 3 phase socket from the board (This is what I will do) and then tap 1 of the phases with a junction box to power the machine.
You have to be careful with running a second 13A socket from the board and make sure it is on the same phase as the other.
I think there are rules to avoid have rings on different phases close together. Reason being is that although each socket would provide 230V there would be around 415V between the two lives from each socket.Last edited by Clive S; 15-06-2017 at 11:39 AM.
15-06-2017 #44
It's a commercial environment I have plenty of free space on the fuse board to run a new line in I was going to fit a 3 phase 5 wire 32amp socket then tap one of the phases to a junction box and from there to the machine and to 2 plug sockets. I have an electrician on site so he will do it lol although I have actually done it before and he checked it out and said I did it correct ;) Since everything else on site is 3 phase it makes sense to fit a 3 phase socket and of course future proofing as I see 3 phase in my CNC future lol.
I was told if you tap 1 phase of 3 to get 230v mains you mustn't have a load on the other 2 phases and the load should be balanced over all 3 phases.
The fuse box for the unit is unusually large (Hence loads of empty space) because before my dad bought the place it was Kraft foods and they filled it with industrial refrigerators. He had so much fun ripping out the stainless and weighing it in good old days of cash ;)
I have 10+ 3 phase sockets and at least 4 single phase 16 amp sockets if anyone wants one for free, I always cut them off the machines we scrap if they're still mint and 99% of the machines we scrap were plugged into the wall once when installed and unplugged once when removed for scrapping lol.
I have more issues with recovering the SY cable as my Brother is always stealing that for his fridges but I managed to squirrel away 20m's when no one was looking.Last edited by Desertboy; 15-06-2017 at 02:59 PM.
15-06-2017 #45
I have the 3 phase plug, socket (With Isolator) & SY cable (Free of course) so would only need to buy a short length (2m) of 5 wire armoured cabling to the fuse box, luckily where I have the machine the fuse box is the other side of the wall.
My spindle came this morning and when I put it in the spindle mount and weighed them both 6.5kg's add in my z axis and we getting close to 10kg's (Maybe more) on the gantry. So to combat flex I'm toying with pouring 2K epoxy resin into the cavities in the extrusion which I think will increase rigidity considerably whilst being impossible to tell from the outside lol.
I may encase the frame and gantry in angle steel but my worry is finding angle steel that's straight! I would avoid using it on the side where the rails or ballscrews are mounted.Last edited by Desertboy; 15-06-2017 at 03:07 PM.
15-06-2017 #46
Thanks for the advice, this is not in a home so unsure how many sockets are on the ring but if I ever move this to my house this will be a consideration.
I have a caravan kettle, It's single phase but only 750w I just rounded up. It's very annoying lol as it takes ages to boil but it was of course free ;)http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
15-06-2017 #47
I did have a great score today wasn't free in fact cost me £145 4 years ago from ebay.com from Japan but I lost it, it was assumed that it had been binned. I then forgot I bought it lol. Was looking in drawers at work for my missing linear rail and found it was a nice surprise and in my mindset it was free as I had essentially written it off.
A 2nd hand (But mint) THK C3 ground ballscrew with C3 mounts and bearings ~40cm in total length from tip to tip which I think I will use for my Z axis instead. I would have the ballscrew cut down and end machined BUT being C3 I think I would be ruining the accuracy or paying more than the ballscrew is worth to me so I should leave it alone.
Spindle came as well ;)Last edited by Desertboy; 15-06-2017 at 03:19 PM.
15-06-2017 #48I was told if you tap 1 phase of 3 to get 230v mains you mustn't have a load on the other 2 phases and the load should be balanced over all 3 phases.
The danger can come in domestic use if a guy runs an extension lead to his neighbours house its possible to get the high voltage in fault conditions..Clive
15-06-2017 #49
Thanks for the reply, I actually meant to write
"1 phase of 3 to get 230v mains you mustn't have a load on the other 2 phases otherwise the load will be unbalanced over all 3 phases." What they were stressing to me was that it was ok for the load not be balanced if I used only 1 phase but if I used all 3 phases (Say 3 different single phase circuits) then it should be balanced. But I have no idea if I was fed bollocks lol.
I think I am misunderstanding balanced but I'm also repeating what I was told by an electrician. I was only talking from the POV that I have a 3 phase input to a 5 wire socket and I take 1 live, the ground and the earth. Not a home situation if I was doing this at home I'd run 32amp Twin and earth from spare slot on the board and add the correct breaker. I've done this before and it cost me ~£45 last time for the wire and breaker, my house hasn't burnt down yet lol.
I'm not sure I understand how my neighbour balances me because one side house has been empty for a year and the other side they work nights so I would think the 3 phases are not balanced unless balance isn't load which is what I assumed it to be. Also what happens when it doesn't divide by 3? When I was thinking of balance I was thinking it needed to be equal draw on all 3 phases a once which is how 3 phase motors work of course.
I'm not an electrician lol but interested and would like to improve my leccy skills especially as the last electrician I had at home I ended up having to fix his dodgy wiring lol. (Patched my Electric oven cable in the wall with 13amp!) Trust a trader my fucking arse.
I just realised reading your post that I need to check which phase is which in the fuse box before I wire this up I think a volt meter should be the right tool for the job. I'm assuming they put the different phases on different rows.Last edited by Desertboy; 15-06-2017 at 06:07 PM.
15-06-2017 #50Thanks for the reply, I actually meant to write
For three phase to run correctly they must all balance out. (I am not having go)
Regarding the oven I believe there are some that run from a 13A socket these days...Clive
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
