13-10-2017 #251
The Following User Says Thank You to Desertboy For This Useful Post:
13-10-2017 #252
Looking good mate!
The Following User Says Thank You to AlexDoran For This Useful Post:
13-10-2017 #253
I especially like the blood at the bottom of the case (Mine of course)
Decided not to go back today was sent some drawings from a solidworks designer and not happy at all I know I can draw them better in Fusion how we want them but not sure how lol.
Taking a while to get used to not having a co-ordinate system anymore and working from offsets but I'm hoping if I keep my head down I can get the drawings finished today.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
13-10-2017 #254
The Following User Says Thank You to Zeeflyboy For This Useful Post:
16-10-2017 #255
I think in the old days you used to sacrifice someone else's blood.
Started the wiring today ;) Only going to wire up 2 of the stall protections for now (For the dual ballscrew) once it works we'll add in the other 2.
I'm guessing the plus/minus dir don't matter which way round they are wired and can be changed in Mach 3/LinuxCNCLast edited by Desertboy; 16-10-2017 at 06:19 PM.
19-10-2017 #256
Finally skanked a 2nd hand piece of ply to use for shelves almost having to go buy one there :)
Wired up a little more, now I need the CY cable so I can wire to the motors, limit switchs will go on last as I haven't even decided how to mount them yet past a brief look around the machine for ideas.
I think I might need to use the machine to make the limit switch mounts as I want them to be rock solid out of aluminium rather than 3d print them.
I hope I wired the emergency in correctly (Only 2 of 4 wired in at moment) wired them to a barrier connector block joining the live to live and neutral to neutral than ran 1 wire each to the right inputs on the BOB.
I assume it's similar with the limit switches, wire all the grounds to 1 connector and then from there to the common ground (same as emergency) then wire the limit lives. X&Z to the X input, One Y limit switch to the Y input and the 2nd Y limit switch to the Z?
I did ask before but forgot the answer what power should I feed the BOB
Looks like theres 2 PC live 5v's inputs, with 1 gnd, also 12-24v input and a 5v USB? Which one should I use? I'm going to have this sat next to the pc that will control it and I'll get a 4 pin molex extension to tap a spare output from the PSU so will have both 5v & 12v available.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
19-10-2017 #257
5V comes from USB, 12 - 24V - external PSU. Same BOB was used on my previous Emco lathe.
The Following User Says Thank You to Chaz For This Useful Post:
19-10-2017 #258
But there's 3 pins bottom right marked PC GND and 2 marked PC 5v I was wondering are these inputs? if so do they replace the usb? I'm going to run a 4 pin molex from the PC power supply so have bother 5v and 12v to tap would be neater than USB and possibly more reliable?
It's nice that the BOB came with not even one piece of paper lol I had to google around to find that image or what looks like my board.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
19-10-2017 #259
19-10-2017 #260
Dumb question but the spindle has 4 pins marked 1, 2, 3 & 4 which is the ground? (I think it's 4)
To check if it's grounded do I just undo the bolts at the top and it comes off?
Should I just solder directly to those pins or is there a connector I crimp on?Last edited by Desertboy; 19-10-2017 at 02:25 PM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
