Thread: Laser exhaust filtration...
I am looking to filter my laser exhaust so i can cut with the windows closed, it seems this is possible with carbon filters, has anyone made a home-brew filter using the carbon hydroponic filter tubes - these are pretty cheap, have a post-filter cloth on them and i should think a box with two or three 4-5" units on them would suit a 6" blower from the laser?
Better to use multiple smaller filters as the 6" ones are expensive and with multiple units you get more surface area easily/cheaper.
My plan is to build it under the laser in the empty space between the legs.
Any thoughts??
25-04-2017 #2
That sounds like it should work, would it be worth running the exhaust through a couple of re-usable oiled reticulated foam filters to reduce the level of particulates first?
25-04-2017 #3
Yes would need pre-filter for the big muck, was looking at fitting a HEPA filter.
25-04-2017 #4
I once worked in a business which used electrostatic filters to take smoke particles out of air, I don't know if it's a viable home shop option.
25-04-2017 #5
We used to have those units at work when the canteen was smoking permitted, they did work surprisingly well but were pretty big.
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM -
new laser
By mike techserv in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 06-06-2009, 02:17 PM
