Quote Originally Posted by BillTodd View Post
It's coming on nicely :)
Do you have the covers and levers in place? If not you'll be feeling the cross-slide gears spinning as you move the carriage. [one nice Hardinge feature is the ability to cut a perfect 30' taper by engaging both cross-feed and carriage feed at the same time]
I can only just feel the clutch drag on the cross slide if I wind the handle fast. Otherwise, the clutches are free.
The clutches should be adjusted to "...engage and disengage when the ball lever is between 10' and 20' above horizontal."
The clutch covers and levers are not yet in place. I need to strip them for repainting and cleaning. So I guess they are both fully engaged while I am winding the carriage hand wheel. I nearly panicked when I first wound the handle before I guessed at the clutch. I better get on with the covers and adjustment so I can be happy all is well.
One of the clutch spindles looks like it might have seized at one time, but I've decided to leave that and see if it causes a problem. If I'm not carefull I'll rebuild every part and I'm not sure that it's necessary on a machine with a low duty cycle.
Thanks for that Bill
