  1. #9
    A bleed resistor might be useful while you are testing, but once you have a driver or two wired to the power supply, they look like a waste of time. When I checked my machine, the stepper driver power supply was down to a few volts within seconds of cutting power. Any resistor that drains down faster than that is going to need to be a fairly high wattage item, and is going to produce more heat than you probably want in the control box.
    Provided that the drivers are energising the stepper coils, and are connected, and that there are no failures in the system, and that there is no e-stop isolation.
    I'll spend the £1 extra on any >50VDC PSU. Pays your money, takes your choice.
  2. The Following User Says Thank You to Doddy For This Useful Post:
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
