09-10-2017 #131
Thank you very much lads for the help, so on the back of the bottom enclosure box I have 3 pins which a kettle like cable plug into:
This currently is plugged into the power supply box for my controller, can I just taop into these 3 pins and then wire some more wires to the spindle controller l, n and gnd?
09-10-2017 #132
I imagine that would be fine, can't see it drawing more Amps than that plug is designed for.
Alex
09-10-2017 #133
Can't see the amp rating for the IEC socket but looks like it should be fine anything over 10amp is in the zone. If it wasn't for some reason you can buy a new higher rated socket very easily on ebay for <£3 but the size of those pins I'm sure that's 10amp minimum.
A good place to skank these sockets is old PC power supplies for pikeys like me ;)http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
09-10-2017 #134
Again thank you very much lads, will probably have a go at finishing this wiring tomorrow night and report back :-)
09-10-2017 #135
09-10-2017 #136
What are the two terminals on the left? Power in? If so they will go there from the PSU.
Alex
09-10-2017 #137
10-10-2017 #138
Will read again mate, took some more pics as well. 1 min
10-10-2017 #139
Ah yes that makes sense except im not sure what wires go from the power pack to the spindle pcb. One main question though, at the moment, the power comes into the planet enclosure from the way via a kettle/pc like plug. It then goes to a switch on the front of the enclosure. It is then wired from the switch to the l, n and gnd of the enclosure power pack. If I link the L, N and gnd from here to the spindle power pack above would these cables handle it do you think or do I need to rewire in a thicker wire?
I have also wired the cable which goes to the spindle itself wrong, I have now connected this to the terminals which are labelled motor - & +.
Here is a few pics:
10-10-2017 #140
They say motor - &+ so I think I wired these up wrong, think these are supposed to go to the actual spindle?
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
