Thread: Advice on buying servos.
23-07-2017 #61
23-07-2017 #62
What size timing pulleys would you suggest for 200 or 400 watt servos? I was thinking that 5M 9mm wide belt should be about right. Centres should be around 100mm.
24-07-2017 #63
I'd say 15mm belt width minimum.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
24-07-2017 #64
If you download the Gates DF software, it will generate suitable drive options.
30-07-2017 #65
Just in case you helpful fellows haven't seen my new thread on trying to connect up the drivers to the BOB - here it is: http://www.mycncuk.com/threads/11159...ut-board-Mach3
26-08-2017 #66
Hi guys, I'm going to build a machine to drill and tapping one part, I'm thinking use a servo for tapping and a regular spindle for drilling. Using a regular servo I can do rigid M3 tapping on 2mm aluminium sheet? Have anyone experience with something similar? Tks
Enviado de meu Redmi Note 4 usando Tapatalk
26-08-2017 #67..Clive
26-08-2017 #68
You can also do rigid tapping with UCCNC, and with Mach3/4 with the right motion controller.
Gerry
26-08-2017 #69
26-08-2017 #70
CS-LAB AC-servos + SIMdrive
By blim in forum Stepper & Servo MotorsReplies: 0Last Post: 20-02-2017, 12:52 PM -
Novice- need buying advice
By davespg996 in forum New Member IntroductionsReplies: 1Last Post: 09-02-2017, 11:12 AM -
Advice on Buying a Benchtop CNC
By Richb in forum Marketplace DiscussionReplies: 12Last Post: 27-06-2016, 06:43 PM -
Mitsubushi Servos
By Chaz in forum General ElectronicsReplies: 0Last Post: 24-04-2016, 08:08 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
