Thread: New start
Page 32 of 41 FirstFirst ... 223031323334 ... LastLast
  1. #311
    Post the G-code
  2. #312
    Been playing some more :D
    Look at this video, what might be causing this weird motion?
    To fast motion for set kernel speed or just funky g code?
    Have cut circles with constant speed so this was a first :)
    https://m.youtube.com/watch?v=hlvP9uEJP8g
    The fact that it looks the same each rotation would suggest to me its the G-code itself, it could be made up of arcs not radii and the machine could be in exact-stop mode maybe?
  3. #313
    Post the G-code
    Alright, go easy on me as I have no clue what Im doing in cam :D
    Attached Files Attached Files
  4. #314
    Removed
  5. #315
    You have not posted your gcode you appear to have posted the ini file
    I don't think so?
    When I open it it's :
    (No. 1: Part 1)
    G00 X16.9301 Y32.4734
    G00 Z0.5000
    G01 Z0.0000 F600 S24000
    G01 X17.0971 Y32.2580 Z-0.1363
    G01 X17.5547 Y31.6925 Z-0.5000
    G01 X17.0971 Y32.2580 Z-0.8637
    G01 X16.9301 Y32.4734 Z-1.0000
    G01 X17.0971 Y32.2580 F1200
    G01 X18.3224 Y30.7439
    G01 X18.3753 Y30.6802
    G03 X165.3861 Y35.5432 I71.6236 J59.3169
    G03 X168.5055 Y40.1417 I-73.9716 J53.5375
    G01 X168.5497 Y40.2117
    G01 X169.5325 Y41.7967
    G01 X170.2938 Y43.0831
    G01 X170.5245 Y43.4729
    G01 X171.4812 Y45.1695
    G01 X171.5210 Y45.2421
    And so on..
  6. #316
    Sorry you are correct for some reason I down loaded it to a Chromebook then had to rename it and it showed up as a warco.ini file upon checking again it must have been in cache. Strange!!
    Anyway in looks like it is the Cam giving you the problems with straight line segments
  7. #317
    Lives in East Lothian, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    Unless those straight line moves cause an abrupt direction change that creates a corner angle larger than the set corner break angle/corner rounding settings which would force an exact stop, then they shouldn't cause any problems.
    Has exact stop mode (G61) been enabled in your controller?
    I don't see it in your G-code file, but you could try adding a G64 to the beginning to see if things improve.
  8. #318
    And having just run the figures, all is revealed.
    The short moves are creating two 180deg turns, which will be triggering exact stops.
    And as they're part of a depth change, I'm guessing you need to look at your lead in move settings.
  9. #319
    Thanks for the help guys!
    I'm greatly relieved that my weak camskills are the culprit :)
    Guess do it again, do it right is in order!
  10. #320
    Strange code that what did you create it in.?
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
