Thread: New start
Page 14 of 41 FirstFirst ... 4121314151624 ... LastLast
  1. #131
    No idea who that is.. and I get the feeling I should be glad for it ;)
  2. #132
    More bracket power!
    The cablecarrier gets crooked in the end.. but havent fastened all the bolts yet.
    Need to shorten some so they dont stick out hehe
  3. The Following User Says Thank You to Nr1madman For This Useful Post:
  4. #133
    Quick question?
    Been making my cablechain brackets from 5mm thick steel angle (had it laying about)
    Brackets for proximity swithes..
    Ok to use 3mm thick aluminium brackets from unknown ali quality?
    Guess they have to be resistent to vibrations?
  5. #134
    3mm will be fine, the switches have no mass really so vibration will not be an issue.
  6. The Following 2 Users Say Thank You to Davek0974 For This Useful Post:
  7. #135
  8. #136
    Not much happening at my end other than a question.
    My steppers drives accept both ac and dc.
    Is it worth it to do the rectifier and caps to get dc or can I just run ac directly and trust my cheapo drives to have enough capacitans to handle back emf?
  9. #137
    Lives in Marple Stockport, United Kingdom. Last Activity: 41 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I personally would go down the conventional tried and tested route with a toroidal transformer and rectifier with caps.
  10. The Following User Says Thank You to Clive S For This Useful Post:
  11. #138
    Im leaning towards that route...
    There is no way there could be thats big caps in the drives.. so I guess that if I go ac my toroidal transformer will get a beating? Especially since its a 500VA and not overspeced for my application?
  12. #139
    I considered using AC with my my AM882h's but when one of them blew and I replaced it I got an AM882 which is DC only.
    I might be wrong here but I think if the drive is rated for AC you wouldn't need caps they're only there to smooth out the DC. That said it wasn't hard I was scared of the PSU build and yes I did blow one up ;) but it really was drill a couple of holes, bolt stuff on and solder 6 wires just double check you wiring and don't plug the wires into the rectifier the wrong way round.
  13. #140
    Haha ;)
    Well Im not scared of the process.. but I got a shitload of smaller caps so alot more than 6 solderpoints :D
    Im about halfway through but I cant solder with any kids around.. they just have to touch everything ;)
    I figured since the drives provide the motors with dc then some internal conversion must happen in the drives if using ac supply...?
    Anyway.. it will look cool if I finish so I guess I will stick to the original plan!
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
