Page 1 of 3 123 LastLast
    Hello everyone,
    My name is Gilad, i'm 30 and i work as a software engineer.
    for the past 6 months or so iv'e been working on this project mainly for educational purposes.
    the machine was designed to mill hard and soft metals while being light and graceful enough to be run in my apartment:)
    Technical stuff
    - 20mm Hiwin linear rails on all axis
    - 20mm/10mm pitch C7 grade ballscrews and bearings on all axis
    - machined parts (incl the base) will be Al 7075 T6
    - milling head: 8000rpm ATC BT30 90mm spindle, 1.8kw AC servo
    - Y axis Al profiles are Item's 120X120mm heavy variant
    - X axis Al profile is item's 160X80mm heavy variant
    - gantry and side profiles will be filled with epoxy granite
    - motion servo's X4 nema34 clearpath servo (CPM-SDSK-3421P-ELN)
    - max travel 800X330X290mm
    i'm gonna keep this thread updated with the latest images and videos of the build so stay tuned.
    the machine:
Name:	Screen Shot 2017-07-24 at 5.19.03.jpg
ID:	22273Click image for larger version.
Name:	Screen Shot 2017-07-24 at 5.24.16.jpg
ID:	22275Click image for larger version.
Name:	Screen Shot 2017-07-24 at 5.24.00.jpg
ID:	22276Click image for larger version.
ID:	22277Click image for larger version.
ID:	22278Click image for larger version.
ID:	22279Click image for larger version.
ID:	22281Click image for larger version.
ID:	22282Click image for larger version.
  2. The Following User Says Thank You to giladv For This Useful Post:
  3. #2
    Quote Originally Posted by giladv View Post
    Deal
    .Me
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Hi Gilad and welcome to the the forum, It looks a nice project. How about a link to the spindle? I will be following with interest
  5. #4
    thanks!
    it's skyfire's BT30
    http://skyfirecnc.com/picshow2.asp?id=14
  6. #5
    the machine:
    I am sure it's going to be a nice machine but based on my experience I'd suggest making some changes before it's too late.
    My frame was originally similar to yours but I had to remove those wheels because of shaking caused by the G-forces. A fast machine with heavy gantry and Z movements will generate far too much shaking even if all the four wheels are locked. I changed my design, moved the wheels and the machine is now lowered to the floor on four wooden blocks, efficiently reducing vibrations and shaking. The wheels are still there but they don't touch the floor and gets lowered when the machine needs to be moved.
    I assume your machine is going to be much faster than mine, considering you are using servos, so it would be a shame if you had to lower the speed and acceleration just to prevent the violent shake, so consider this before it is too late.
  7. #6
    @A_Camera, you are absolutely right, also i wouldn't be able to level the machine with the wheels.
    i thought about a hybrid solution of using 2 wheels at the back and 2 anti-vibration legs at the front for stability.
    there will also be corner brackets all around.
    could you share an image of your solution?
    thanks!
  8. #7
    hi Clive, thanks!
    i used the BT30 spindle from skyfire
  9. #8
    thanks!
    There is really nothing to show. The machine is resting on four wooden blocks and the wheel is suspended by about a millimetre or two. If I need to move the machine I lift one end, remove two of the blocks, lower on the wheels and do the same for the other two feet. This gives me enough clearance to move it around. I think four steady feet is better than two with wheels.
  10. #9
    Nice work so far. Can you show the detail behind the Z axis top covers. I'm guessing servo drive via belt to the top of the ATC spindle pulley?
    Also, are the gantry ends just covers, or machined from solid (!)
    I've looked at that skyfire spindle many times before and been very tempted. Let us know how you get on with it.
  11. #10
    Chaz's Avatar
    Ive also considered the skyfire spindle. I may pull the trigger on one and report back.
  1. Questions on using a moving gantry style mini-mill...
    By Davek0974 in forum Machine Discussion
    Last Post: 13-07-2016, 06:07 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. Best all round mill/router? Vertical mill or gantry router?
  4. eBay: X2 Style CNC Mill For Sale
    By davidimurray in forum Items On eBay UK
    Last Post: 04-10-2013, 10:26 PM
  5. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
