    Hi guys,
    Well, it's still there.... After changing from Gecko dive to AM882 drivers, I am still getting random X and Z this time, faults, as in the tool has missed 5 to 6 cm of travel in an instant.
    Ran for 55 minutes doing a constant Z level face, with long straight lines, no errors.
    Changed to a parallel operation, with constant Z changing, constant Y position every 3 seconds then move 1mm, and constant X reversing left to right while Z up and down.
    The error that occurred within 5 minutes of the new operation starting, ended up shifting my X position by 70mm, AND shifting my Z up by 3mm - no fault detected by AM882 because speed too low for stall detection.... or because fault was not a stall.
    Thought that the X/Z error was caused by a jam and motor loosing torque after overheating ( which still may have something to do with it ) So I started Parallel again while motor was boiling hot and pushed with about 40kgs force and was utterly unable to cause any kind of jam, let alone 70mm of jam.
    Re-homed position, reduced speed by 50% and ran operation for 25 minutes , and through the previous anomily without error ( not a G-Code error ).
    So now I'm thinking I have only ever had this error when running parallel operations with changing Z values..... Could there be something happening momentarily with the motion controller getting overloaded from all the commands and it be responsible?
    Assuming this is not a lack of stepper power, or a machine jam related error then what else could cause it to jam at higher speed, but seemingly not at 50% speed?
    Nick
    Quote Originally Posted by dachopper View Post
    motion controller...
    Good question, what motion controller are you using? Do you have a USB breakout board in play?
    what else could cause it to jam...
    Good question, are you 100% positive everything is mechanically sound with the machine?
    .Me
    UC400 ETH controller, UCCNC software
    I don't know, I can turn the ball screws by hand from end to end..... what more could cause the X axis to seemingly bind, not get noticed by the 822, and then immediately unbind in reverse direction?
    Next step is GOPRO an entire cut in the air, and see if it jams unloaded under inertia or no jam and program telling it to move?
    Have you checked the pulse width from the UC400 ETH?, I don't know how but I've noticed its an option in the UCCNC software. The AM882 needs >2.5us for reliable operation. Worth a look?
    Does the power supply have enough output!
    Peter
    Pulse width is not an option. It's a function of the kernel frequency. I believe that you need to use 200Khz or less to get 2.5us pulse width.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Using 50 khz , .1 sec com buffer, and 300 line look ahead
  1. Help with Problem X axis Stepper Please
    By howser37 in forum Gantry/Router Machines & Building
    Last Post: 09-02-2017, 06:31 PM
  2. Which single stepper for long axis?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 24-05-2015, 08:39 AM
  3. Connecting BOB one axis to 2 stepper drivers
    By Noplace in forum General Electronics
    Last Post: 10-02-2015, 11:56 AM
  4. Z axis error woes
    Last Post: 18-02-2012, 03:07 PM
  5. The dreaded task of workshop tidying!
    By m_c in forum Milling Machines, Builds & Conversions
    Last Post: 26-03-2011, 08:07 PM
