Page 4 of 14 FirstFirst ... 23456 ... LastLast
  1. #31
    Hi everyone,
    The build is progressing slowly, mainly just waiting for parcels to arrive, i now have the extrusion and all of the bolts / fixings. I am struggling to figure out what my PSU requirements are, i was wondering if someone might be able to offer some advice?
    I am using 4nm Nema 23's, and using Leadshine AM882 drivers from China.
    This is the datasheet for the Motors i have:
    PDF
    Link for the stepper drivers:
    AM882
    Am i right in thinking that to get the most from the motors and drivers that i am going to need a 68 - 80v PSU? What amperage rating will it need to be? 20A+?
    Again any help would be greatly appreciated, thanks.
    Alex
  2. #32
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    68V with a 650 Va transformer. See Joe's excellent vid.
    https://www.youtube.com/watch?v=4OoQ...zD30sZjtp_VyqY
  4. #33
    Hi Clive,
    Many Thanks, just to clarify - that would be 68v & 650Watts? I am really not comfortable building my own PSU, and i cannot seem to find that spec one, so probably i will get two 500Watt PSU's at least then i know neither one will be high loaded, and the ones i am looking at nearly half in price if you buy more than one:
    Power Supply
    What do you think?
    Alex
  5. #34
    Quote Originally Posted by AlexDoran View Post
    Hi Clive,
    Power Supply
    What do you think?
    Alex
    Have a look at the vid. They are easy to build and only require a transformer, rectifier, and 3 Caps. If you are going with a switch mode power supply you will need one a lot bigger to handle the back EMF.
  7. #35
    Hi Clive,
    Power Supply
    What do you think?
    Alex
    I'm going to build one on advice of Clive S (Also Chaz pointed out do it right!) but if I was to buy one I'd buy these
    https://www.omc-stepperonline.com/po...-s-350-60.html
    UK shipping as well get one per motor.
  8. #36
    And I think you would be disappointed in the result and it will cost you double by the time you add duty etc.
  9. The Following User Says Thank You to Clive S For This Useful Post:
  10. #37
    No duty on that one Clive as long as you select UK shipping ($3 more) but you're probably right about the disappointed lol.
    I found most the stepperonline stuff is available for either Germany or UK shipping so no import tax and quick shipping but unfortunately not the AM882's :(
    I found them through CNCzone where they've been getting rave reviews from some of the purchasers.
  11. #38
    In what way does the performance differ?? I was planning to use one 500Watt PSU per 2 Stepper Drivers?
    If not could anyone link me to where I could get the parts to build one??
    Alex
  12. #39
    Alex
    https://www.rapidonline.com/50a-brid...al-case-519318 1 of
    https://www.rapidonline.com/samwha-h...acitor-11-3121 3 of
    https://www.rapidonline.com/lcr-ep08...-clamp-11-3004 3 of
    https://www.rapidonline.com/vigortro...-x-25v-88-0034
    Some people like 24-0-24v I generally use the above
  13. The Following User Says Thank You to Clive S For This Useful Post:
  14. #40
    Thanks for the shopping list ;) Was looking for the previous post were you posted this for me but couldn't find it, this time going to order it tonight.
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. NEW MEMBER: new member building a cnc router
  3. Building a plasma table, need advice.
    By superclarkey in forum Plasma Table Machines
    Last Post: 20-09-2016, 04:57 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. Building a hybrid CNC mill. Need advice and recommendations
