Page 3 of 21 FirstFirst 1234513 ... LastLast
  1. #21
    Quote Originally Posted by driftspin View Post
    I have no good idea what the shaking forces are like in real life.
    These depend on the mass of the moving item and your acceleration/deceleration curves.
    Don't forget - acceleration/deceleration is king of the hill, its more important than travelling velocity, far more, as it will directly affect the path following ability of the software controller - with these figures too low you will see bad corner rounding etc where the trajectory planner cannot perform the moves in time, the only solution then, if you cant increase accel/decel is to lower the speed, this then gives you issues with cutter burning etc - its a vicious circle but all determined by your acceleration/deceleration curves.
    My plasma machine only has a very light gantry - no motor, no cut forces, and it can shake quite badly at times, that has a steel frame too.
    Always build as stiff as possible :)
  2. #22
    Yes, as stiff as possible. Thats the way. If you use trochoidal HSM toolpaths /you will / all will shake very seriously if not stiff and heavy
    Hi guys,
    A little progress update.
    First layer of paint two tone black and white.
    What do you guys think?
    grtz Bert.
  4. The Following User Says Thank You to driftspin For This Useful Post:
  5. #24
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Hi guys,
    grtz Bert.
    Can't see the gantry moving yet.
  6. #25
    Hi Clive S.
    Hahah no, no movement yet.
    Progress is slow.
    Work related issues use up near all of my time. Well it pays for the bills.
    I am still working on the gantry.
    I need to get some bracing in, in the gantry uprights. Also i need to finish beefing up the mounting surfaces, some welds need finishing.
    When all that is done the big pour is next.
    After that a lot of big decisions are to be made.
    I am near ready to order the linear parts.
    I need advice on ballascrew end machining for pulley's.
    Also .. will quality angle bearing bf bk type blocks fixed / float setup do?
    Does one gain lots of rigidity by going fixed fixed? is it much more complicated to setup ?
    I am now designing based on fixed/float setup.
    So maximum speeds vs screw rpm vs pitch vs screw length and diameter are based on fixed float.
    Grtz. Bert
  7. #26
    Looking good but I would have added another member to the top of the black frame work to support the underside of the white cross members. Not too late to bolt something in and shim or epoxy any gaps.
    Fixed float is fine for the screws but I'm thinking of fixed fixed on my long axis (as per Boyans machine) to reduce a slight buzz / vibration when the machine is towards one end. In theory you might worry about heat and expansion but for the amount I use my machine and the speeds etc I think it is a low risk. Not sure yet but might make it with a spring preload . . . Or keep it simple and lock it in place.
  8. #27
    Hi router CNC,
    There will be 4 bolt on diagonals from the middle crossmember when electric panel and additional equipment is fitted.
    Grtz Bert.
  9. #28
    At the moment my 3m long ball screws in Fixed/Fixed config are without a glitch. Though as i said somewhere, when i start machining very fast like more than 12m/min then the rotating nuts start to heat and heat the screws. I think the fact that the gantry is ~200kg and moves with such high acceleration plus the speed , helps that. Which is cured by additional greasing prior to that. Otherwise no problems till now.
    I think one of the biggest problems when DIYcnc is not locking the bolts with a thread locker. Now i lock any bolt on a machine. Not only the obvious that need that. That is also valid for the shafts and the pulleys. A must do , i would say.
  10. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  11. #29
    Buy locktite, noted :-)
  12. #30
    Hi guys,
    I am about ready for the big pour.
    Planning to do it this week or next.
    I plan to put the frame under a tarp with a thermostat controlled heater during curing.
    And set it to 25 C.
    Now i need some looking over my shoulder before ordering linearcomponents.
    I have a quote from Fred.
    The shopping list:
    Rail.
    2pcs HIWIN HGR20-L1830mm Linear rail
    2pcs HIWIN HGR20-L1000mm Linear rail
    2pcs HIWIN HGR20-L500mm Linear rail
    12pcs HIWIN HGH20CA Linear carriage
    Ballscrews rolled C7.
    End machining fixed float for a pulley
    Z-axis
    1set C7 RM1610-L350mm Ball screw with ballnut
    Change Length F to 30mm*
    Y-axis
    1set C7 RM1610-L1150mm Ball screw with ballnut
    X-axis
    2 sets C7 RM2010-L1700mm Ball screw with ballnut
    2pcs 1610 Ballnut Housing
    2pcs 2010 Ballnut Housing
    2 sets bk bf12 1610
    2sets bk bf15 2010
    Upgrade all of the 4set BK/BF* to Superior bearing type.
    Any thoughts?
    Grtz Bert
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
