    http://www.ebay.co.uk/itm/1523042469...&ul_noapp=true
    i'm looking to machine wood only on it, no metal and maybe some plastics. do you think this will be ok. Tolerance is not too important as it will be all arty type stuff. opinions please
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 50 Minutes Ago Has been a member for 9-10 years. Has a total post count of 1,602. Received thanks 110 times, giving thanks to others 69 times.
    It *should*. Accuracy will likely be the issue however if this is not too much of an issue for you, might be fine.
    There are many of these around, I'm sure ive seen them cheaper.
    hi chaz. any idea where you have seen them cheaper. the only place I have seen is china and then you get vat and import on them so doesn't work out
    cheaper. shipped from Germany as well.
    what about this one? harmonic drive they say.
    I cannot see any accuracy problem, maybe only in the axis alignment. the issues are resolution and torque. with the 6:1 reduction, at 100 mm diameter one full motor step will translate in 0.27 mm of movement.
    harmonic drives are in a different league, if they are for real inside..
    Quote Originally Posted by johngoodrich View Post
    When I ordered my ballscrews the import tax should have been £68 when they arrived they were marked as 2nd hand ballscrews with a value of $10 each, customs didn't buy this but only put £15 in import tax on.
    Import tax is luck of the draw but personally from China I'm pretty lucky anything from the US I get screwed on to the full value.
  6. The Following User Says Thank You to Desertboy For This Useful Post:
  7. #6
    I thought these bolt to the bed rotating chuck things usually came with a worm drive and an index wheel/pin.
    Sticking a stepper in place of the index handle is a CNC conversion.
    Replacing the worm wheel with a toothed pulley sounds like a Chinese CNC conversion. More for selling than using.
    Maybe you want to engrave toothpicks and this is exactly what you need.
    Alternatively, maybe if you bought it as an incomplete conversion, played with it, decided what resolution your usage required, replaced their timing pulley with a nice anti-backlash worm from HPC gears, tried it with the stepper then replaced the stepper with one of those singleton servo drives doing the rounds on eBay.
    That could work.
  8. #7
    I have one of the type in the first link in the OP, I chose it for the decent through capacity which you don't get with harmonic drive versions, it worked well enough as standard but I added a link bar and bearings outboard at the back behind the belt to take bending load off the stepper shaft and was then able to add a belt tensioning pulley bearing.
    A few hours work and a few quid in bearings yielded something which is up to 4-axis machining in Ally and Steel using tooling up to 12mm and 7000rpm.
    I had a good indexing head but I believe that a converted/ home brew worm/wheel job is more of a bodge than pulleys, belts & bearings because long term under CNC use gears and plain bearings will require more maintenance, more expensive maintenance and more complex maintenance.
    - Nick
  9. #8
    Double Post, Sorry guys, gremlins on the interface!
  10. #9
    I have been considering something similar for quite some time now, but can't make up my mind about it. In theory it would be very useful for me, it would save time because it would turn around the work piece automatically, but maybe the work piece would vibrate too much so it would be useless for what I am doing, so I am not sure. Never the less, there are plenty on eBay as well, shipping from Germany most of the ones I found.
    Anyway, I am interested in the subject, as well as the use of it and the experience people have.
  11. #10
    Has anyone bought one of these harmonic drive index chuck thingies? Are they any good? Is the lack of a through shaft putting you off? Who will Magicniner contradict next? So many questions, life is too short for all these questions.
  1. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  2. B Axis indexing and easy workflow for repetitive cuts 4-axis
    By deemoss in forum General Discussion
    Last Post: 21-06-2017, 12:34 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. CNC 4th Axis at work
    By Lee Roberts in forum Machine Discussion
    Last Post: 31-07-2009, 11:35 PM
