    Hi
    I am setting up my Huanyang HY02D223B and spindle and I have a question I hope you guys can help with. I have the 2.2kw 220v 8.5A 400Hz spindle. I am trying to determine the correct setting for PD143 (No. of motor poles).
    Using this formula Ns = 120*f/P
    P=120*f/Ns = 120*50Hz/24000rpm gives me a result of 0.25 . which does not make sense!
    What have I got wrong?
    What is the correct setting for PD143?
    Thanks in advance.
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by iforeman View Post
    Hi
    Thanks in advance.
    I think it is two.
    http://www.mycncuk.com/threads/5814-...ighlight=pd143
    I think that the reason that your formula gives the wrong answer is that the actual operating frequency when the spindle is at 24000RPM is 400Hz, not 50Hz! So, the answer will be 8 times larger which gives 2, as Clive says.
  1. Huanyang VFD dl Error
    By charlieuk in forum Spindles & Drive Motors
    Last Post: 12-05-2017, 07:59 PM
  2. Wiring Huanyang HY02D223B
    By Stan in forum Milling Machines, Builds & Conversions
    Last Post: 25-03-2017, 07:25 AM
  3. Huanyang VFD repair
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 27-01-2017, 10:57 AM
  4. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
  5. Huanyang hy02d223b frequence convertor problem
    By frans cop in forum Motor Drivers & Controllers
    Last Post: 14-07-2015, 10:33 AM
