    I'm looking for your comments please. This would be a gantry style CNC router. The Gantry is 150mm x 75mm steel rectangular tube, and the frame is 75mm x 75mm square tube. 1610 ballscrew, 20mm Hiwin HGH20 or similar.
    The point of this design is to put the ballscrew directly above the linear guide, with the gantry mount sandwiched between the ball screw and linear guide carriages. I do not believe I have seen this before.
    The motivations for this:
    1. Ease of machining of the frame. The ballscrew mounts/motor mounts will be machined in the same plane as the linear guide rail surface. Alignment made easy.
    2. An attempt to "hide" the ballscrew from inadvertent movement. This doesn't really achieve this, but it gets it away from the outside of the frame.
    3. I think it looks cool.
    Thanks for your comments.
ID:	23157Click image for larger version.
ID:	23156Click image for larger version.
ID:	23155Click image for larger version.
ID:	23154Click image for larger version.
  1. Ball screw advice
    By Darren in forum Lead Screws, Nuts & Supports
    Last Post: 10-04-2016, 10:52 PM
  2. How to machine a ball screw
    By Tom_Nelson in forum Milling Machines, Builds & Conversions
    Last Post: 22-07-2015, 10:50 AM
  3. Replies: 4
    Last Post: 02-01-2015, 08:32 AM
  4. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  5. Stationary Ball Screw
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 29-12-2009, 01:12 PM
