19-11-2017 #1
Good day
I am having a problem with "erratic cutting"..i.e. if you cut a square shape using a "multipass cut"..the first pass "sort of" cuts fine then the second and third cut start "moving/cutting" to the right handside of the first cut so you end up with 3 cuts in different places( asuming you selected a 3 pass cut)..
I said "sort of" cuts fine because the shape is recognisable, but, on cutting the x-axis it seems the x-axis movement is "jerky" in places.
I have run the motors from side to side and forward backward using Mach3 and keyboard keys...the movement is fine...so it seems like a Mach3 setup requirement.
Can anyone assist...or preferably is there a "standard" setup on Mach3 available for a 6040 using Nema stepper drive motors.
Thanks Roy- South Africa
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
FOR SALE: CNC 4 axis Foam Cutting Machine
By Am1707 in forum Items For SaleReplies: 1Last Post: 25-06-2015, 01:43 PM -
Chinese 6040 from uk eBay seller x axis problem
By CommanderKenyon in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-02-2015, 02:13 AM -
axis movement jamming
By Skydeals in forum Linear & Rotary MotionReplies: 3Last Post: 18-12-2014, 10:27 AM -
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM
