  1. #31
    Lives in Plymouth, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    if its ethernet, how can it be LPT??
    It talks ethernet to the PC, but instead of direct outputs like the CSMIO range, it has a set of 5 "parallel port" style output connectors. In fact, they are standard PC board headers and each needs to be connected (simply) to a terminal strip (or cheap BOB as the connectors carry the same signals as a parallel port) to give access to the connections or (much better) to a custom BOB which provides opto-isolation plus the potential for 24V signalling. There is a fancy BOB specifically designed to go with it that provides opto-isolated access to all its IO ports. Not sure if it can also handle differential signalling for connection to stepper drivers. The combination isn't cheap - the BOB costs as much as the controller board, I think, but the combination plus UCCNC is competitive with the IP-M if you also add in Mach3.
    (edit - Gerry was quicker off the mark! UB1 - that's the board I was thinking of)
  2. #32
    Its a 5LPT board with ethernet connection? So you would use 5 BOB's too get full functionality??
    Just guessing, couldn't see a UB1 win the site ;)
    Edit,
    typing at same time ;)
    Makes sense now, I still prefer the CSMIO if not just for its "completeness" and rugged build.
  3. #33
    "Full Functionality" would depend on the users needs. And there are 1 port, 2 port, and 3 port breakout boards. The UB1 uses 3 of the ports.
    http://www.cncroom.com/interface-cards/uc300eth-ub1
    You don't need the 5LPT board with the UB1, so you save a few bucks there.
    But it relies on flawed software, which is the main issue.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  4. #34
    Yes its one drawback and i have worked around it, I guess i could ask CSLABS if they have done anything on it as the linked stuff was a while back, doubtful though which is a pity IMHO.
  5. #35
    About as likely as retrofitting the dual-motor support from the IP-S into the IP-M, more's the pity.
