    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 22 Hours Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    Has anyone any recommendations to go looking at best replacement bearings for a 2.2Kw W/C spindle, had one company come back at £300 plus each for ceramic.
    Phill
    Chaz's Avatar
    Phill
    Cheaper to probably just buy a new spindle.
    I've replaced bearings on motors and other equipment knowing that the replacements I fit are from a local industrial bearing supplier and will give a normal service life, probably outlasting Chinese variants the OEM used by many times,
    Regards,
    Nick
    Any bearing chosen must be capable of sustaining the required RPM of a spindle, also the grease you use is crucial at those speeds.
    I replaced a bearing on a 20K RPM spindle for a pin router, the replacement was a FAG B7206-C-T-P4S-UL
    it replaced a Japan NSK 7206C and the grease I used was SKF LGLT 2/0.2
    Of course that bearing is most likely not suitable for your spindle but it gives an idea of what I used, and it's still going strong.
    FAG bearings were the best price/performace offering I could find at the time but I can't remember which supplier I used.(it would be the cheapest though)
    phill05's Avatar
    Thanks guys for all the input I don't like the idea of throwing the spindle away and buy a new one just to save money, I will take a look at the FAG bearings.
    Phill
    Chaz's Avatar
    Phill
    Suppose its costs vs reward. A more expensive set of bearings will last longer but cost more. If changing the bearings is not too onerous, why not fit 'budget' ones (assuming you get OK runout) and just change them every 24 months?
    Phill
    Do you want the best, or the cheapest? very high quality spindle bearings cost far more than complete chinese spindles.
    I'd pick up some mid range quality bearings, and get some good grease, like Kluber Isoflex NBU15.
    I'd expect the cost is going to be at least half the price of a new spindle, and a fair amount of work to change them. A new spindle may be a better option. Certainly a much easier option.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. Replacement cables
    By Paul B in forum Chinese Machines
    Last Post: 25-04-2017, 11:24 AM
  2. Replacement Boxford 160 chuck
    By Saracen in forum Boxford Lathes
    Last Post: 21-01-2016, 06:53 PM
  3. Bulb replacement
    By calida in forum Laser Machines & Building
    Last Post: 19-01-2016, 11:03 PM
  4. Replacement Part Required.
    By wildfowler54 in forum Bridgeport Milling Machines
    Last Post: 06-01-2016, 08:42 PM
  5. taper roller bearings vs deep groove ball bearings
    By dsc in forum Linear & Rotary Motion
    Last Post: 10-03-2014, 08:06 AM
