    With cnc on a cross slide is the digital readout set up to measure the actual diameter of the part, or the size of cut, (ie the movement is half the digital readout)?
    https://www.youtube.com/watch?v=o5AXKYctOMs
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Colin Barron View Post
    It can be set to either. It can be set in the DRO with a button or software to read radius or Dia..
    Hi Clive thanks for the reply,
    In the case of my SZGH CNC1000TDb it uses: set P16 on User parameters,diameter or radius programming.
    The stepper pulses need to be matched at 10,000 on the stepper drive and in Axis Parameter No.17 Numerator of X Electron gear also set to 10,000.
    I will set the No18 moved distance in diameter (P16) and see if that is correct.
    Regards
    Colin
  1. Sieg KX-3 cross (Y) travel increase
    By SteamCAD in forum Sieg Milling Machines
    Last Post: 08-05-2019, 05:23 AM
  2. SBR20 measurement
    By kingcreaky in forum General Discussion
    Last Post: 17-07-2013, 05:42 PM
  3. spindle cross section view
    By routercnc in forum Tool & Tooling Technology
    Last Post: 05-08-2011, 12:55 AM
  4. Spindle Speed Measurement
    By clockmaker in forum Spindles & Drive Motors
    Last Post: 04-12-2010, 11:38 PM
  5. Digital protractors/angle measurement - worth buying or not?
    Last Post: 15-05-2010, 07:26 PM
