Hi Guys
I do not know if the standard mach3 fusion post will work for the 8 station ATC Denford Triac or if it will need editing, and if so how.
Many thanks
Steve
26-12-2017 #2
Try running it and see.
Although a basic Fanuc 0M post processor may be more suitable, and there are a couple Denford post processors in the autodesk library at http://cam.autodesk.com/posts/Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
26-12-2017 #3
26-12-2017 #4
That's normally because you're using an unsuitable tool type (i.e. a drill, and not an endmill), a toll with too big a diameter, and/or the toolpath settings aren't letting it run at tight enough of an arc to fit in the hole.
You might want to have a look at this video for various ways to bore a hole - https://www.youtube.com/watch?v=nKbEzSleF14
(NYCNC vids are usually pretty good, and their Fusion Friday videos have a good few tips in them)Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
26-12-2017 #5
Morning m_c
Tar very much for the help. Yes I like the videos that mycnc John does, learnt good bits from him. In fusion I was just trying to drill 2 3.5mm holes I selected a 3.5mm twist drill. I will have to go back over fusion videos again beacuse no matter how simple the thing I try to do fusion says no!
Thanks again
26-12-2017 #6
If you're trying to drill the holes, then you need to use the drilling option.
Bore is essentially a variation of a 2D pocket, and uses milling cutters to helix/spiral into holes.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
FOR SALE: Denford Triac PC inc Denford table plus chucks, and Denford CD software etc
By Piero franchi in forum Items For SaleReplies: 8Last Post: 14-02-2017, 04:47 PM -
FOR SALE: Denford Triac + Denford Orac + other stuff
By Clive S in forum Items For SaleReplies: 6Last Post: 06-02-2017, 11:47 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
eBay: Denford Triac CNC milling machine mill mach3
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 19-11-2012, 01:46 PM
