05-01-2018 #1
Hi there I know there is a lot of "oh please tell me what to use etc" I have seen a few and keep seeing Fusion 360 is the go to but I don't want to subscribe to a payment plan for software I would much like to buy and own myself.
I am still searching through all various cam software's and then watching utube vids on them or downloading free trial software etc but am just wondering what is the next best thing that you can own yourself?
I am going to get Mach4
I have XP windows
CNC 6040
I am aiming to do mainly woodworking on my 6040.
Cheers for your time guys
05-01-2018 #2
For home and hobby users, and small business users (can't remember the threshold but I seem to remember something like $100K/year turnover), F360 is free. Download the trial subscription and when it gets close to expiry, you can sign up for the free version. Basically the full version, but free. However, there are people who do not like this because data is held in the cloud (in practice, on Autodesk-managed servers) and there is always the possibility that the "free" deal will be withdrawn.
I hear good things about FreeCAD, but I haven't used it (I'm a F360 user for quite a lot of what I do).
When I first started using a CNC router, around 5 years ago, I tried a range of free software for both CAD and CAM. However, I had quite a few problems. That was 5 years ago and things might well have changed but I bought Vectric Vcarve and found it both easy to use and pretty powerful. It's not cheap but is good. It is designed for woodworkers rather than general engineering, and I still use it for some jobs as it is much quicker and easier than F360 (and is excellent for sign-making as its lettering engraving capabilities are very good). There are a number of different products in the Vectric range, and you can download trial copies if you are interested.
I'm sure you will get lots of other opinions - this is a very personal area and what suits one person might not suit another.Last edited by Neale; 05-01-2018 at 11:46 PM.
06-01-2018 #3I am aiming to do mainly woodworking on my 6040.
Regarding Mach4, do a lot of research before spending your money....Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
06-01-2018 #4
I use CamBam for all my design work. It is a 2D package which is fine for almost everything you may want to cut out with a 3-axis router. It is easy to learn and use, has a pay-once-get-free-updates-for-life license and there is an active community producing some very useful add-ons including v-carved text.
You can buy it as a package with MACH3 or, for a low-cost option, the resulting G-code works well on CNClinux software.
Kit
CAD and CAM can be separate packages if you want them to be if you want to spread the risk of F360 changing T&Cs (no sign of this by the way). I use a range of CAD software and they all produce IGES files which you can import into F360 and make use of the extensive CAM features.
Obviously the files are not linked this way and if you spot an issue doing the CAM you have to edit on the CAD program and export again. Rarely happens in practice and well worth it for the F360 CAM features.
The Vectric stuff is great (I have some myself) but there is a cost so I would do some comparisons with F360 before deciding. By the way F360 only runs on 64 bit so bare that in mind as last time I checked Mach 3 does not so if using that to drive the machine you need 2 PCs or dual boot etc
07-01-2018 #6
Turbocad pro with the CAM and wood working plugin would also be an excellent choice if you search ebay.com you can normally find last years version for 1/3 the price of this years.
I use fusion now BUT I would highly recommend turbocad and see a time in the near future where I'll buy the latest copy (Mine is 8 years old) and subscribe to fusion as well.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
07-01-2018 #7
07-01-2018 #8
I have a spare pc with parallel port on board, free if you collect I'm in Leicester.
07-01-2018 #9
I'm with Kitwn and also use CamBam.
Before you spend money on CAD software you need to decide why you need it. If it's for 3D work then it's maybe required but for 2.5D work there should be enough CAD in CamBam to cover your requirements.
That may be true of other CAM software but I don't have experience of those.Last edited by EddyCurrent; 07-01-2018 at 02:58 PM.
m_c thanks for the correction
fusion 360 cnc parts
By charlieuk in forum Fusion 360Replies: 4Last Post: 24-05-2017, 02:23 PM -
Limited Offer! 50% off a 1-year subscription to Autodesk ArtCAM Standard
By DogBeagle in forum ArtcamReplies: 6Last Post: 23-05-2017, 01:16 PM -
Fusion Problems
By cropwell in forum Fusion 360Replies: 7Last Post: 04-03-2017, 07:39 PM -
I need advise again
By habibuzziwa in forum General DiscussionReplies: 14Last Post: 08-10-2012, 10:08 AM -
I need advise
By habibuzziwa in forum General DiscussionReplies: 7Last Post: 03-10-2012, 10:50 AM
