Thread: TTS Tooling system
21-01-2018 #11
thought of fitting a tool length probe? the probes i use repeat at 0.005mm max error on my cnc
21-01-2018 #12
21-01-2018 #13
Did some assessment on repeatability, found two results...
Took a few random tools, zeroed the Z axis with my Haimer probe and then swapped tools, going to G1 Z0 F100...
T1 0mm
T3 +0.06mm
T8 +0.09mm
T10 +0.08mm
Now, before i dig any further, do those figures seem reasonable for a Bridgeport conversion??
No point looking for issues that are OK or can't be fixed.
Second result - with the Haimer probe fitted, if i repeatedly approach Z0 at F100 I get perfect result of zero every time. If I increase speed to F200 I get an error of +0.03mm, going to F300 or above I get an error of +0.04mm every time.
My thoughts are a following error in the servo setup maybe, overshooting and not correcting possibly?
21-01-2018 #14
if your on facebook- these are the probes i use and sell in the uk
https://www.facebook.com/groups/cncm...c_location=ufi
The Following User Says Thank You to battwell For This Useful Post:
22-01-2018 #15
Dave - I had that problem with an IP/M but was able to fix it by using a slightly earlier version of Mach3. Not sure which CSMIO box you are using but have you tried that? Sorry if you've already been down that path! It's solid for me me, though, both for initial setting and using the fixed touchplate for second-operation resetting.
22-01-2018 #16
IIRC i am on 062 - gave up messing some time back as i needed to use it, I might revisit this when i get to setting up my powered knee axis.
22-01-2018 #17
does probing work correctly as a seperate macro? (not in m6)
22-01-2018 #18
22-01-2018 #19
As JAZZCNC said, yes it does - i use it on my mini-mill profile for the bridgeport, this has the high-speed spindle and no chance of using tool length offsets at all as the collet is part of the spindle, on this side of the machine i just tick "ignore tool changes" and output one file for each tool number. Its a little tedious but handy if the file is not 100% as they are smaller files.
22-01-2018 #20
thats where a tool length probe on the machine comes in real handy. mine is always accurate to under 0.01mm - i hate having to re touch off etc. probably the best thing i ever fitted. (so good i now stock and sell them in the uk)
RFQ: Semi automatic welding system Linear beam control system
By richway in forum Projects, Jobs & RequestsReplies: 0Last Post: 24-01-2017, 08:54 PM -
FOR SALE: Various tooling
By millietess in forum Items For SaleReplies: 5Last Post: 12-01-2015, 10:00 AM -
FOR SALE: tooling for sale
By davy in forum Items For SaleReplies: 4Last Post: 10-11-2012, 11:37 PM -
Tooling
By p1lts in forum Tool & Tooling TechnologyReplies: 9Last Post: 11-10-2011, 08:14 PM -
HSK Tooling
By Dairsie in forum Tool & Tooling TechnologyReplies: 3Last Post: 02-09-2011, 10:07 PM
