Page 15 of 15 FirstFirst ... 5131415
  1. #141
    Paint?, I'd use some of the hard enamel paints used on the machines of old - check out Paragon paints for something as reassuringly expensive as hammerite, though altogether better!
    Did you give it a good stir? I've never had any trouble with Hammerite.
  2. #142
    diycnc's Avatar
    Lives in Manchester, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 6-7 years. Has a total post count of 66. Received thanks 2 times, giving thanks to others 11 times.
    Machinery enamle sounds like the right paint! Going with a tin and brush this time. Never have much luck with spray paints.
    Cover on the Z axis will go over the whole thing, like this one on one of JazzCnc machines.
    http://www.mycncuk.com/threads/8701-...m-made-machine
    Looks like aluminium from the picture.
  3. #143
    diycnc's Avatar
    Moving onto final assembly at last. Total gave up with paint in the end. After 4 tests with the second tin of enamel paint that all went soft even after drying for over a month, im going for the bear metal look! Its bone dry in the garage so dont see it been a problem.
    Y (forward - backwards) axis rails have been leveled and are parallel, and both ball screws are have been aligned with the axis.
    Struggling with aligning the pulleys that connect both ball screws to my single stepper. Any tips for getting them aligned would be appreciated.
    ThanksClick image for larger version.
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
  5. Woo, my first 'proper' part!
    By craigrobbo in forum Woodworking Project Showcase
    Last Post: 05-08-2012, 02:51 PM
