  1. Hi Folks,
    I looking for some guidance on a replacement 4 axis controller and driver boards.
    I have a DIY cnc set from Roy cnc (I think) which water has gotten into, the only thing left is the enclosure.
    I have been looking about without much success, there is a few on ebay but I don't know what I'm buying.
    Any suggestions would be much appreciated.
    Patrick
    Chaz's Avatar
    First question, to drive what, steppers or servos?
    Once you know then, what budget and what control system?
    That will help answer the question.
  3. I have a Boxford Midimill which was converted to run Mach3.
    As for the budget around £200.
    Patrick
    Chaz's Avatar
    Im just about to do an upgrade on my CNC Lathe to a more expensive Centroid system.
    I'll have my setup for sale if you are interested.
    Its a Pokeys 57U board + Expansion board. It runs off USB, so need for serial etc, let me know if interested.
    If you have an existing parallel port etc, you can just get a cheap BOB on ebay for under £10. Do you have any pics of the bit that has failed?
  5. I have PM you.
    Patrick
  6. Any more suggestions folks/
    cheers
    Patrick
    Lives in East Lothian, United Kingdom. Last Activity: 3 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    Are you looking for something ready built and just needing steppers/computer connected, or individual parts to build a control box?
  8. Not too worried if I have to build up myself, as long as it's reliable.
    In that case, cheap BOB from eBay. Just search for CNC Breakout Board. Take your pick of any of the 5axis one that every man and their dog seem to be selling. Cheap and do the job.
    Then select your choice of stepper drivers.
    Assuming relatively small steppers (up to 5A), at the cheap end, TB6600 drivers.
    Bit more expensive are the DM542 drives. Next up would be something like AM882's.
    Only thing I can't remember, is if that board can handle spindle drives that are not isolated i.e. the typical basic KBIC/SCR drives used for DC spindle motors.
  10. Thanks for your help with this.
    Patrick
  1. Replies: 1
  2. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
  3. FOR SALE: LCD Module, VGA Driver, OSD Control Panel, Inverter unused, Boxed
    Last Post: 10-12-2011, 11:36 AM
  4. Driver wiring to my computer for mach3 to control
    By AdCNC in forum Motor Drivers & Controllers
    Last Post: 01-04-2010, 12:27 AM
  5. Driver box
    By John S in forum General Electronics
    Last Post: 21-06-2009, 12:46 PM
