29-03-2018 #21
That just means it's a generic 2 Axis readout that is not specifically made for a lathe and is thus incorrectly labelled for lathe use.
If it were a Lathe Specific model it would have lathe specific functions including Diameter and Radius display of X and a table of offsets for tools/holders, like this one-
That's my 0.75Kw, 20 year old Siemens Micromaster Vector on the left BTW ;-)You think that's too expensive? You're not a Model Engineer are you? :D
29-03-2018 #22
I'd research lathe tool turrets some more, there's a reason all the commercial ones don't work like that, if you need to centre drill, pilot drill and finish drill your bore then ream it how will you do that and face the end and put a shoulder on the OD and part off?
And that's a pretty simple part! Try to avoid designing something that is NBG as soon as it's finished.You think that's too expensive? You're not a Model Engineer are you? :D
29-03-2018 #23
Yes I know, really it doesn't matter what letters you label an axis with, you could also call them Red, Green and Blue. I was just in a frivolous mood. I have the SINO SDS6 2V readout, it just seems to have more functions I have no clue how to use :(....... [sad old bugger dribbling].
Rob
29-03-2018 #24
A simple part for metal machining perhaps :). But I am turning wood, I really dont need all those functions! Here's a vid that is pretty close to what I want:
https://www.youtube.com/watch?v=GB5fMNte844
I guess the reason people do vertical tool turrets is to fit more tools in there, but if I am OK limiting myself to 3 or 4 its not really an issue. And I get to change the angle of approach for the tools, which is pretty important for me.
29-03-2018 #25
I've just replaced a fairly ancient Anilam display on my lathe with a new Easson display, as well as swapping the old glass scales for new magnetic scales. The Easson display is switchable, lathe/mill. I was a little surprised when I set it to "lathe" mode and the 3-axis display became X and Y, as I was expecting X and Z. No big deal, just not the usual convention. It does have selectable Dia/Rad on the correct axis, and also has a tool offset table (although I'm not sure of the resetting accuracy of my quick-change toolpost).
Yet Another Noob. Looking for Kit or Guide
By RatherBeMaking in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 09-04-2015, 09:52 AM -
NEW MEMBER: Noob
By Karl CNC Scenex in forum New Member IntroductionsReplies: 7Last Post: 20-12-2012, 11:16 AM -
NEW MEMBER: Hi from a CNC noob, London
By masonman in forum New Member IntroductionsReplies: 1Last Post: 17-09-2010, 09:57 PM -
NEW MEMBER: noob log in...
By flez1966 in forum New Member IntroductionsReplies: 2Last Post: 12-10-2009, 06:33 AM -
NEW MEMBER: Another Noob!
By Jaff in forum New Member IntroductionsReplies: 3Last Post: 16-09-2009, 10:46 PM
