    Hi.
    I have just bought a Dust Commander Vortex and am setting it up with my CNC machine.
    At the moment I am going to use my Henry hoover which I have been using to follow the mill round as it cuts, but it is laborious doing this so I want to set up a vac connected to the brush shoe.
    I assume the Henry will not be powerful enough. Can you recommend a small inexpensive vac that is a better choice over the Henry? (Space is an issue, so nothing large)
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    I've been using one of these for a few years. It's taken a lot of abuse in that time and just keeps on working. If it breaks, I'll be getting another one. However, the noise is one reason I use ear defenders when running the router... Price has gone up a bit (I paid about £35, as I remember) but still looks a good buy. But someone else will point you at something better and cheaper - they always do when I suggest something!
    Thanks.
    I'm not sure what the power of the Henry is, but that looks more substantial. Cheers :)
  5. #4
    I have been using the same one as Neale and it IS noisy. Domestic vacuum cleaners have recently been subject to legislation to limit the power, but that doesn't seem to apply to workshop vacs. The one mentioned is 1250W as is this one https://www.aldi.co.uk/workzone-elec...80727177603400 which is currently on sale. I would buy one, but I have already spent my pocket money this week
    Brushed motor vacs are not really intended for long switch-on periods and the brushless motor ones are much quieter and designed to run continuously. I have thought about buying something like this http://www.power-motor.com/Products/...uumCleane.html and building my own canister using the remains of my old vac when it burns out (hopefully not literally!).
    My current setup is this Click image for larger version.
  6. #5
    The Henry i believe is a 2 stage motor, so miles better. I use 2 stage motor and it sucks incredibly well. Not always needed, but sometimes i cut in a way that brushes could not be used, so then it sucks small particles from air above cut.
    The Henry I have is 680w. Is a 2 stage better than the Wikes one?
    I see Henry do a more powerful 1060w industrial one.
  8. #7
    What's the cyclone setup you are using, and how well does it work? I keep thinking of having a go at knocking up something but can't quite get it to the top of the to-do list.
  9. #8
    Hi Neale,
    In answer to your query -----
    One of the problems with the cyclone is that - if it picks up any greasy dust, it sticks to the wall of the cyclone and kills the effect. Also it does not seem to separate fine MDF dust very well.
    The actual setup is one of these https://www.ebay.co.uk/itm/Plastic-C...sRqlROdF1V_Abg and an ash can which I bought some time ago for £10 - ish. Then there were a couple of 3D printed hose adapters and blanking plates.
    If it all fell to pieces, I wouldn't put it at the top of my list to repair it. For what I do a straight vac cleaner would be enough.
  10. The Following User Says Thank You to cropwell For This Useful Post:
  11. #9
    I’ve been using the Dyson DC27 for almost 2 years, its used mainly for sucking up carbon it’s lasted well and sucked up damp alloy chips 🤦🏻*♂️ the motors started playing now so I’ve replaced it with this.
    https://rover.ebay.com/rover/0/0/0?m...2F132456079693
    Listings wrong it claims 1250W but the box and instructions state 1000W will be testing it at the weekend, but if it’s crap then I will replace with another trusty Dyson.
  12. #10
    I also use a wickes own brand, can't fault it!
  1. Diy dust shoe dust strip bristles
    By charlieuk in forum Dust Extraction & Collection
    Last Post: 18-06-2019, 10:47 AM
  2. Building a cnc dust boot / dust skirt extractor
    By craynerd in forum Workshop & Equipment
    Last Post: 13-03-2016, 01:50 PM
  3. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  4. How to cut small parts on a vacuum bed
    By Nathan_Partington in forum Machine Discussion
    Last Post: 11-05-2012, 11:45 AM
  5. Which kit would you recommend?
    By ian823478 in forum Motor Drivers & Controllers
    Last Post: 08-04-2012, 11:05 PM
