    Chaz's Avatar
    Looking for a high quality homing switch so that I can get my Lathe's X Axis set correctly and allow my tool changer to be consistent.
    When looking at proximity switches, how do you know if its high quality? I did see a test a while ago where a guy on youtube tested a number of them and found a mechanical switch with no arm seemed to be the most reliable.
    As I dont have index homing (stepper), what are my options?
    I don't think the homing accuracy would influence the tool changer as you will have touched off on the part.
    The standard proxy switched I find OK
    Chaz's Avatar
    Thing is, I use Machine home as the starting point / offset.
    Ok I have not got a turret. But I thought you would have to touch off on the part and that would ref the tool changer position. So sorry can't help further
    Chaz's Avatar
    Nope. The aim of the machine zero is to be the absolute reference. This means that each tool is offset against that point. So clearly if it moves, then my tools are not referenced correctly anymore.
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    I used an opto slot sensor on my old lathe, and there was never any measurable variation. I used RS part number 480-5231 however I see that part has now been discontinued. The only problem was I had to make sure a bit swarf hadn't landed in the slot prior to homing, as I never bothered enclosing it.
    The new lathe uses proximity combined with servo index homing.
    You could combine a proximity or microswitch with a slot sensor on the stepper, provided you can add a suitable slot to the stepper/ballscrew, to essentially give you a poor mans index homing.
  7. The Following User Says Thank You to m_c For This Useful Post:
  8. #7
    Chaz
    I have a Balluff mechanical switch which are very good, I don't mind sending it over for you to try.
    Just pm me your address if you want to try it. I will post a link to the switch if I can find it on the RS site.
    Regards
    Andy
  9. #8
    Chaz's Avatar
    Thanks, something like this - https://uk.rs-online.com/web/p/photo...nsors/1254515/ ?
  10. #9
    Chaz's Avatar
    Quote Originally Posted by audioandy View Post
    Chaz
    Regards
    Andy
    Thanks, will send you the address. What do they cost?
  11. #10
    Chaz's Avatar
    Does this need a 'receiving part' or anything that it can pick up in the slot?
  1. Homing with proximity sensors
    By routerdriver in forum General Electronics
    Last Post: 19-12-2017, 06:32 PM
  2. Problem with homing
    By Andyman in forum Gantry/Router Machines & Building
    Last Post: 22-03-2016, 07:56 PM
  3. homing problems in mach3
    By johngoodrich in forum Artsoft Mach (3 & 4)
    Last Post: 17-09-2011, 08:28 PM
  4. Homing Switches
    By m_c in forum General Electronics
    Last Post: 04-11-2010, 11:21 PM
  5. Limits or homing switchs???
    By Ross77 in forum Computer Software
    Last Post: 28-03-2010, 03:17 AM
