    I have an A3HSRMi2 which is still as built by Boxford. I'm confident I could convert it to run under Mach3 but what steps are required after the conversion to enable the software to work correctly ?
    I've converted a Boxford 160 lathe to use the USBCNC board but I write all the gcode for that manually. For what I need to create on the router that's just not a possibility.
    When I looked into Mach3 for the lathe, there seemed to be a minefield of things such as post-processors etc, at which point my head exploded and I decided to stick with what I had.
    I use TurboCAD to generate parts for my 3d printers, and to mock up pieces for the lathe, but I guess I would need a more powerful 3D modelling software to be able to push files to the router ?
    Adrian.
    Chaz's Avatar
    Fusion 360, and find a suitable post processor. Loads of online youtube vids etc about it. That said, if it was me, Id be going Acorn Centroid vs Mach (just did this on a Harrison M300 machine).
    Chaz - Did you fit a spindle encoder for screwcutting?
    Chaz's Avatar
    Quote Originally Posted by Leadhead View Post
    Indeed. Did my first trial cut of a thread the other day, success, nothing broke. The thread isnt right (not deep enough) but its all working as needed.
    Chas - Thanks did you use a C3?
    Chaz's Avatar
    C3?
    Optical encoder C3 from CNCforYou. Many of the posters and Utubers seem to refer to this?
    Chaz's Avatar
    Ah sorry no.
    I bought a Hengsler one from an Ebay seller not far from me.
    https://www.ebay.co.uk/usr/shotmaste...p2047675.l2559
    He seems to have them (or similar ones) all the time. For £40 ish, cant go wrong, good quality.
    https://www.ebay.co.uk/itm/Hengstler...t/123073649461
    Similar to that but mine doesnt have the collet setup, it has a thread thing, a bit more finicky.
  1. CONVERSION: Sx2 plus cnc conversion
    By Lewywri89 in forum Conversion Build Logs
    Last Post: 30-11-2014, 11:36 PM
  2. CONVERSION: Need some help with a new SIEG SX2 Plus CNC Conversion
    By Onocyclone in forum Conversion Build Logs
    Last Post: 17-09-2014, 01:00 PM
  3. CONVERSION: Myford VM-B CNC Conversion.
    By John S in forum Conversion Build Logs
    Last Post: 25-03-2014, 10:10 PM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Bridgeport Conversion
