I have an A3HSRMi2 which is still as built by Boxford. I'm confident I could convert it to run under Mach3 but what steps are required after the conversion to enable the software to work correctly ?
I've converted a Boxford 160 lathe to use the USBCNC board but I write all the gcode for that manually. For what I need to create on the router that's just not a possibility.
When I looked into Mach3 for the lathe, there seemed to be a minefield of things such as post-processors etc, at which point my head exploded and I decided to stick with what I had.
I use TurboCAD to generate parts for my 3d printers, and to mock up pieces for the lathe, but I guess I would need a more powerful 3D modelling software to be able to push files to the router ?
Adrian.
06-05-2018 #2
Fusion 360, and find a suitable post processor. Loads of online youtube vids etc about it. That said, if it was me, Id be going Acorn Centroid vs Mach (just did this on a Harrison M300 machine).
07-05-2018 #3
Chaz - Did you fit a spindle encoder for screwcutting?
07-05-2018 #4
07-05-2018 #5
Chas - Thanks did you use a C3?
07-05-2018 #6
CONVERSION: Sx2 plus cnc conversion
By Lewywri89 in forum Conversion Build LogsReplies: 11Last Post: 30-11-2014, 11:36 PM -
CONVERSION: Need some help with a new SIEG SX2 Plus CNC Conversion
By Onocyclone in forum Conversion Build LogsReplies: 22Last Post: 17-09-2014, 01:00 PM -
CONVERSION: Myford VM-B CNC Conversion.
By John S in forum Conversion Build LogsReplies: 15Last Post: 25-03-2014, 10:10 PM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
