    Hi
    For some reason fusion will not allow me to perform a small pocket of 2mm in my part no matter what operation i try. does anyone have ideas why?
ID:	24186Click image for larger version.
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Could it be that the tool is the same diameter as the pocket is wide..? - Try telling F360 that the end-mill is ⌀1.999mm*
    *It's what I have to do in Vectric's software...
    Wal.
    You could use a ramped profile cut based on one edge of the pocket (slot?)
    To work optimally a lot of CAM users utilise extracted and/or constructed geometry to generate the paths they need rather than purely relying on the solid model,
    - Nick
    I had this problem with a scratchplate for an Ibanez guitar this weekend - the way I got it to work was to get rid of (untick) the Lead In and Lead Out options in the last tab on the toolpath dialogue.
    Hope that helps.
    Edit: Nearly forgot - set the Ramp option if you haven't already.
    Hope that helps.
    That sorted it. Thank you
    Wal.
    i double checked all that and seemed ok. I removed lead in and it seemed to work fine after that. thank you
    No worries and glad it worked.
    I think this "feature" was introduced in the last update or so, as I think it used to drop the lead in/out if there wasn't room for it.
  1. Thread milling shallow bind hole
    By suesi34e in forum Metalwork Discussion
    Last Post: 15-12-2015, 01:03 PM
  2. Tips and tricks for shallow milling/ engraving ?
    By Gasgasbones in forum General Discussion
    Last Post: 11-01-2015, 09:39 PM
  3. Youtube/Video Channel Thread?
    By Washout in forum General Discussion
    Last Post: 29-05-2014, 02:24 PM
  4. where do you get the v groove channel extrusions from
    By nobby in forum Marketplace Discussion
    Last Post: 29-04-2014, 04:19 PM
  5. What's the diffrence in the 5V 4-Channel Relay vs a ZP-4WAY-RB
    By boldford in forum General Electronics
    Last Post: 05-09-2012, 05:25 PM
