Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    Good progress there. The bowing is almost certainly due to the stress relief when the first side was ground. To be frank, I don't know why you bothered to get it ground, since in use you have to put packing under the plate and a felt "blanket" on top, which will take up any small unevenness in the platen. I think the springs are in the wrong place - really you want them to take the weight of the top roller to make it easier to get the plate/blanket sandwich under the roller, then use the screws to apply compression. You have allowed enough space for the plate/blanket?
  2. #32
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hi John,
    Hmm - that's an odd thing to throw in at this stage - it was fairly obvious from my earlier posts that I was going for a 'sprung above' approach. There are a lot of vagaries on putting together one of these presses - so as well as taking advice from good folk such as yourself, I've had to (for better or for worse) go my own way a bit here...
    Anyway - allow me to explain my approach... Instead of a collar, I made a couple of threaded flanges and used a thrust bearing in the take up unit (flange stud-locked and captive to the threaded rod) - this means that there is very little friction turning the pressure adjustment knobs to raise or lower the roller, it's literally as easy as turning a tap.
    As I understand it, the springs have two purposes:
    • sprung under they can aid with lifting the roller
    • sprung over or under they apply a bit of pre-load to the roller to stop it flapping about when not under pressure
    So, the thrust bearing negates the need for the spring to help lift the roller, but that downwards pre-load is still very useful. If you look at the side-on view of the take-up bearing you'll notice a gap between the threaded rod and where it would normally contact the take-up unit.
    This effectively means that the press has a bit of suspension - the roller can still be positioned to kiss the plate or print at lower/softer spring pressure when printing from lino or wood - of course, these gaps can also be shimmed for a hard stop when printing etched plates.
    Ah yes, my mistake - a chunk covered in mill-scale that's been sat in the garden for a few years would have done the job! Joking aside - I totally get your point, but for the price there was no harm in at least attempting to get it as parallel as possible, job worth doing and all that...
    Regarding blankets, yep - there's a fair amount of gap available - not loads, but should be enough. If I run into any problems I have the option to either a. get myself one of those thin rusty plates you've been advocating , or b. deepen the pockets that hold the springs on the underside of the pressure plates.
    This is probably all moot anyway - I'm shite at art...
  3. #33
    Aha! Sorry I didn't appreciate that you had designed the screws to lift as well - that's a refinement that I don't think many presses have!
    Once the press is finished you'll be able to get lots of practice. Ii's probably well worth while finding a printmaking course to learn the basics of grounds, the actual etching process, printing and so on. The studio will have all the materials, acids and so on. It is possible to use aluminium for plates, and etch them with a solution of sodium carbonate (washing soda) - a bit kinder than copper/nitric acid or ferric chloride.
  4. #34
    Wal's Avatar
    Cool tip - cheers John, will look into that.
    I've been reading up a bit on various techniques - I'm quite interested in having a go at generating the line-work digitally and using my CNC gear to do the etching - I put this together in Illustrator a while back:
    So it'll be a combination of old/new techniques - and seeing what happens..!
  5. #35
    Yes, nice. Technically that's engraving - printmakers get hot under the collar about the confusion! You can get a nice variation in the line width by varying the cut depth, not so easy in etching I believe. Or you could use a sprung scribing point on the chuck (non rotating) and scratch through a ground and subsequently etch the plate.
  6. #36
    Wal's Avatar
    Heh - way ahead of me skipper - that's exactly what I'm trying to design at the moment... I have a whole heap of broken small diameter carbide end-mills that I'm thinking of grinding to a point...
  7. #37
    Wal's Avatar
    Right, it's pretty much done, until I figure out any tweaks that may need doing whilst I get to grips with using it - the only obvious one would be the deeper spring pocket to allow for a bigger gap between the top roller and the platen - so far I haven't needed it, but it would afford me some flexibility, so why not..?
    Anyway - here's an animated turnaround:
    And here's a woodcut print I gone and done - normally the shapes are cut into the wood by hand - I do all of the artwork digitally using Photoshop and Illustrator and then CNC cut the wood before inking and printing. Eventually I'll probably combine both methods - just have to see what works for me!
    The digital design:
    The inked wood:
    The print:
    Wal.
  8. #38
    Very nice Wal
  9. The Following User Says Thank You to mekanik For This Useful Post:
  10. #39
    I don't know about it's output, the machine itself is a work of art!
  11. The Following User Says Thank You to magicniner For This Useful Post:
  12. #40
    Wal's Avatar
    Heh, cheers guys!
    Sent from my HTC One M9 using Tapatalk
  1. New drill press. Which???
    By Snapper in forum Metalwork Discussion
    Last Post: 21-01-2017, 10:53 AM
  2. VFD for drill press
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 31-03-2016, 12:09 PM
  3. WANTED: Drill press
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 07:45 AM
  4. RFQ: Press cost question ?
    By Fivetide in forum Projects, Jobs & Requests
    Last Post: 01-12-2012, 08:26 AM
  5. Bearing interference fit / press fit
    By Mad Professor in forum General Discussion
